Resonator, anyone leave it on?
Old Sep 17, 2006 | 02:59 PM
morkable's Avatar
HI , I have the 4" MBRP exhaust, sounds awesome till I am towing my trailer. Has anyone ever tried putting a resonator on it? Do you think this would decrease performance much??
Kevin
Old Sep 18, 2006 | 10:58 AM
stock03's Avatar
I hope this helps. My brother added his original resonator back to his 4" exhaust and has not noticed any change in egt's or performance. His is a 2002, but I don't that matters.
Old Sep 18, 2006 | 12:14 PM
Thenewguy's Avatar
I have an 06 which came with the 4" from the factory, but I did add a high flow diesel muffler. It is pretty loud above 2000 rpm on the outside, but you wouldn't even know it wasn't stock from the inside. I would put the resonator back on and see if it changes. Also, I've heard the location of your tip can cause a drone. Is yours sticking out past the rear quarter? If it isn't you might try that first if you have a bolt on tip. Or change both.
Rtikul8
0
May 8, 2008 03:47 PM
Bad Ramer Jamer
Dec 11, 2005 02:23 AM
Diesel diehard
Feb 10, 2004 08:25 PM
mountainman
Apr 8, 2003 09:49 PM
