reoiling air filter
Old Oct 13, 2004 | 06:26 PM
Jmac's Avatar
reoiling air filter
Hey everyone,
How heavy should the spray be to reoil an AFE PG7 air filter. I know not to overoil it but how do I know how much is sufficient.
thanks
Jamie
Old Oct 13, 2004 | 06:59 PM
Jmac's Avatar
Also is the filter supposed to come squeeky clean b/c mine didn't I cleaned it twice by the directions today and it's free of debree but is still black and oily.
any comments would help
Thanks Jamie
Old Oct 15, 2004 | 04:38 AM
Dodgezilla's Avatar
Whenever I cleaned mine it came very clean. You may want to try leaving the cleaner on it a little longer before hosing it off. The directions say to spray the water from the clean mesh side but I always spray on the dirty side.
As far as the oiling, I just spray enough to cover the whole filter and let it sit a while. I then check to see if there are any light spots and I just do some "Touch-up" oiling. I use a K&N recharger kit which is red so it may be easier to tell if you've got good coverage than if you're using the yellow AFE stuff.. I just try to use as little as possible but still have full coverage. Too much oil and you'll get some restriction.....
EverydayDiesel
22
Jun 3, 2010 12:10 AM
Medicmike14
Feb 17, 2009 09:49 PM
Wildhog
13
Aug 4, 2008 08:07 PM
nfsommer
Apr 16, 2007 09:21 PM
Jmac
Dec 3, 2004 04:09 AM
