Reducing turbo lag
Old Aug 28, 2006 | 11:34 AM
Brambles's Avatar
Reducing turbo lag
Is there a way to get the turbo to spool up faster without spending mega bucks.
When I was shopping for trucks I tested a 1999 5 spd that had a 70 hp chip and different injectors. the turbo spooled as soon as you touched the throttle the feel was awesome, the truck I bought is a 2003 6pd 305 hp engine and it has turbo lag, power is good when it finally decides to spool up but by that time you already have to shift. If I could get it to spool up faster then I would be very happy, are there any negative side effects to having you turbo spool up quicker?
The truck is stock exept for two 3" holes drilled into the front of the air box by the previous owner, I'm not to sure about the BHAF mod because Im in Canada and drive in snow a fair bit and the temps get a little colder
I don't want to risk blowing my clutch but I wouldn't mind a little extra power and mileage, I drive pretty easy but i do like acceleration, not big on top speed though!!
Any help would be greatly appreciated
Brambles
Old Aug 28, 2006 | 11:46 AM
JCLeary's Avatar
It has been my experience that a downloader is the best way to get your turbo spooling quickly. Much quicker than a pressure box.
Old Aug 28, 2006 | 11:54 AM
973604x4's Avatar
i was gonna suggest a boost fooler from Quad....my truck spools much faster now with the boost fooler....but come to think of it, i've never ran my truck on stock fueling with boost fooling....i'll try it and see. The Quadzilla Boost Fooler is not in production yet, i have a beta version.
As stated above, i can also testify that downloaders spool faster than modules....ie Juice module vs Bullydog downloader
Old Aug 28, 2006 | 12:02 PM
Brambles's Avatar
Will modifying the intake system or a differnt muffler make the turbo spool much faster.
Can you use a downloader with the rokktech sensor, what happens when you have to take your truck to the dealer and you have a program downloaded, can you put it back to stock??
Old Aug 28, 2006 | 12:32 PM
973604x4's Avatar
intake and muffler will spool somewhat faster, not a whole lot. I wouldn't try a downloader with a rokktech.....yes downloaders can be put back to stock but they will leave a footprint if the dealer looks hard enough....unless you use a Smarty which i personally wouldn't recomend.
Old Aug 28, 2006 | 04:51 PM
acook's Avatar
Hmm my 06 spools slower with the crazy larry tune on my programer but if you enable the low end fueling option it shoots like a rocket!!!! Not a daily driver in my opinion though.
Old Aug 28, 2006 | 06:07 PM
973604x4's Avatar
Yes, Crazy Larry takes a while to spool because of all of the fuel. If you compare the performance Bullydog program to the Juice on level 5, the Bully spools faster.
If you want that crazy larry to spool in a real hurry and hold boost and pull really hard, get a Quadzilla Boost fooler. It's the best mod i've done since my DTT.
endurancerider
Jul 13, 2011 08:32 AM
zander79
21
Mar 29, 2007 05:35 PM
johnr9q
Jun 6, 2006 11:21 PM
HOHN
Oct 26, 2005 08:36 AM
TXTad
Aug 14, 2003 03:08 PM
