Rebuilt 5.9 excessive black smoke
Old Apr 8, 2019 | 10:56 PM
Bg1490's Avatar
Rebuilt due to dropped valve. Anyways, I had motor rebuilt and injectors rebuild etc. problem I am having is (smarty jr) back to stock. With the lightest touch of throttle is rolling smoke. Cruising speed you still see black haze. Truck seems to run ok!
truck is 04.5 is it possible engine shop used 03-04 style pistons/or injectors place gave me bigger injectors?
i am going to do a boost leak test tomorrow, I also changed air filter checked rail pressure etc everything seems good. Turbo spools etc, I do not have any gauges to check true boost numbers
what’s your guys thoughts?
Old Apr 9, 2019 | 02:17 AM
GabrielMacht's Avatar
To see what different smokes mean click here
Hi.
It appears that injectors are giving too much fuel, hence the black smoke.
Did they rebuilt your injector, or gave them yours and the gave another ones (rebuilt) in return?
Any codes, check engine light on?
Old Apr 9, 2019 | 03:40 PM
Bg1490's Avatar
I checked for boost leaks All good! Injectors were mine that they rebuilt they said.. wondering if they put 03-04 style pistons in with my 04.5+ injectors
needlern32724
Jun 10, 2007 04:14 PM
needlern32724
Mar 16, 2007 03:58 PM
big b
Jan 11, 2004 12:15 PM
BigBlue
Jan 22, 2003 07:49 PM
