Rear Freeze Plug Blew!!!!
Old Apr 21, 2007 | 12:01 AM
  #31
belgianmagic's Avatar
Originally Posted by DF5152
got anymore info on the plate? cost, where to get it, whats involved with the install?
Dan
I second this post
WHERE DO WE GET ONE >???
Old Apr 21, 2007 | 12:03 AM
  #32
95ram's Avatar
is TDR free now???
Sorry I had to.
Old Apr 21, 2007 | 12:09 AM
  #33
53 willys's Avatar
Originally Posted by 95ram
Sorry I had to.
well at least tell me why I can see all pages today but never could before???
Old Apr 21, 2007 | 12:55 AM
  #34
WUnderwood's Avatar
Hot Rod Diesels is where I got mine
phone # is 832-932-1432
hope this helps
Old Apr 21, 2007 | 01:09 AM
  #35
53 willys's Avatar
Originally Posted by RamWheelsBy4
Seems like a nice tool to make it easier to install new plug and/or cover plate. Beats transmission R/R.
http://www.turbodieselregister.com/f...d.php?t=181670
more info on this please
how much and how can we get one
Thanks
Old Apr 21, 2007 | 06:45 AM
  #36
MikeyB's Avatar
Wonder if something like Water Wetter from Redline or Royal Purple will help in these situations??
MikeyB
Old Apr 21, 2007 | 06:54 AM
  #37
wap's Avatar
wap
hope this helps
Same here.
Water wetter is a good idea. I remember somebody sayin it should help.
Old Apr 21, 2007 | 06:57 AM
  #38
Originally Posted by dodgezilla04
i know cummins makes a plate to cover that hole and relocates the heater hose to the back of the motor, where the plug would be. i am going to order one on monday, i looked awhile ago and it was about $54. when i get to work monday and locate it in my parts book, i'll post it here.
COOL THANKS...I'll look for it early in the week
Old Apr 21, 2007 | 07:37 AM
  #39
RamWheelsBy4's Avatar
Thanks
I have not seen anymore info on the tool/plate. If there is any info posted I will pass it along.
Michael at HotRodDiesels installed mine also. Of course mine had to take a 60 mile wrecker ride to get there.
Old Apr 21, 2007 | 07:55 AM
  #40
OldSmokey's Avatar
I think ill get one of these plates, I cracked the block i in my 2000 so i dont want to worry about the cooling system on this truck too. Anyone know it the thermo for the cr's is the same as for the vp truck i have an extra 180 degree thermo in the shop that i could drill and swap for the summer?
Old Apr 21, 2007 | 09:45 AM
  #41
53 willys's Avatar
I don't think any coolant additive is going to lower pressure....and pressure is what makes it blow.....
Old Apr 21, 2007 | 10:39 AM
  #42
CamperAndy's Avatar
I know it may be uncomfortable but operate the cab heater on max when you want to make a run. The heater core runs around the thermostat and thus will prevent the high deferential pressure across the thermostat. Dumping flow from the block back to the pump suction.
Also you can run a low pressure rad cap. Dropping the water pump suction pressure will drop the pump output pressure some.
Anyone ever put a pressure gage on the block to monitor water pressure?? I think you could also set up some type of regulator/relief valve to dump excess pressure from the block back to the rad. It would be nice to know what pressure is required to push the plugs out.
Old Apr 21, 2007 | 01:17 PM
  #43
dodgezilla04's Avatar
i was running redline water wetter, so nope, that wont help. i will get the plate info and post it here monday.
Old Apr 21, 2007 | 03:08 PM
  #44
wap's Avatar
wap
Now that I think about it, maybe the WW was suposed to help keep #6 from melting down so fast, I cant remember. Maybe I have no idea what I am talking about and should just keep my mouth shut too, yes, I think I will do that
BTW, good idea Andy. I would supose running the heater on any settin should help some though, shouldnt it?
Old Apr 22, 2007 | 10:44 PM
  #45
LVTony's Avatar
Isn't the NPG waterless coolant supposed to help by not building pressure? I imagine it's expensive and tedious to convert over, but then you'd be good to go wouldn't you?
