Rail Pressure
Rail Pressure
hey guys,
I just bought a rail pressure and fuel pressure gauge. i havent installed them yet but was wondering what i should be looking at as far as numbers. or what the numbers shouldnt drop below.
Thanks
Nick
Thanks
Nick
For fuel pressure somewhere between 12-20psi.Don't know what the raptor 150 comes set at but it probably falls in this window.
For rail pressure around 7K at idle,17k at cruising speed,23-26k at WOT.All these will vary some depending on the Smarty set up you are running.Running the RP on 3 or 4 will increase the idle and cruising readings but should not change the WOT much.Just remember that high sustained RP is not good on injectors.Its ok for a little playing but then back it down for everyday driving.
ok, thanks guys, and i bought that quad digital rail pressure gauge. but now im hearing that things are going wrong with it? should i send the gauge back before i install it? how does it hook up?
Yeah Quad is usually known for good customer support, but qzilla hasn't been around lately to back that up on the forums. I dealt with Diesel Manor since I bought it there, they deal with Quad for me.
I've been running the one I got from the DTR store for a year now with no problems. I would install it and not worry.
i bought mine here at the dtr store went bad in a week thank TOP on here for getting me another in the mail asap. seems to be hit or miss with then you dont want over 27k at the rail for sure thats what i set mine at
