race question
Old Dec 18, 2007 | 09:08 PM
tt433's Avatar
race question
i was out run by my brothers toyota tundra. my check engine lt came on and showed a code of p0069. what do i need to do to fix that code? what elese do i need to do to my truck?
Old Dec 18, 2007 | 09:43 PM
RamWheelsBy4's Avatar
Definition type Definition
GENERIC MAP - Barometric Pressure Correlation (DTC reinstated)
GENERIC Manifold Absolute Pressure – Barometric Pressure Correlation
Probable Cause:
Manifold Absolute Pressure (MAP) sensor, mechanical fault
Check the MAP sensor connections on your Juice and make sure they are connected completely/correctly would be the first thing I would do.
Old Dec 18, 2007 | 09:48 PM
As far as what to do to beat him, turbo, fuel system, clutch/tc/trans upgrade, studs, nitrous, etc. Or maybe try HOT Juice or Smarty along with appropriate supporting mods.
Old Dec 18, 2007 | 10:17 PM
omaharam's Avatar
Is his a quad cab or regular cab?
Is yours a stick or auto?
Is yours a 305/555 or a 325/600?
Those Tundras are running mid to low 14s. If you're an auto and 325/600, you're going to need the Hot upgrade, pressure box, and TC and VB. That should get you into the high 13s - 14.0s
QWKSLVRZ06
Nov 26, 2011 02:59 AM
BigBully
Mar 18, 2009 10:01 PM
BigJohnston
Feb 7, 2008 06:14 AM
LinearX
14
Jun 14, 2005 04:48 PM
hellotbone
18
Jun 25, 2003 01:16 PM
