Quiet 4 inch system
Old Apr 14, 2008 | 04:00 PM
FSTDL's Avatar
Quiet 4 inch system
My uncle doesn't do the internet thing and had asked me if I knew of a quiet 4 inch system for his 04 2wd 305 hp quad cab.He had ordered a Volant and was putting it on and found out it would not fit and then they told him they didn't make one for his truck.He said his head pipe is around 3 5/8 inch.I am not sure what his has I would guess a 3 1/2 inch but any help would be appreciated.And he wants it quiet.
Thanks again.
Phil
Old Apr 14, 2008 | 04:03 PM
molalla1ton's Avatar
well, my cat fell off along with the stock muffler and I replaced with 2 flow through mufflers v e r y quiet.
Old Apr 14, 2008 | 05:27 PM
GreyTD's Avatar
Any free flow muffler he puts on will be louder than stock, exspecially 24" ones. His exhaust is 3.5" from exhaust elbow to front of muffler and 4" back to tail pipe. If he wants 4" exhaust all the way he will need to get an exhaust system turbo back and replace the cast elbow for true 4". The cast elbow on a 305/555 is 4" at turbo neck down to 3.5" at down pipe. Stick with a longer muffler and it will be quieter.
Old Apr 14, 2008 | 06:08 PM
underwoodbits's Avatar
My donaldson 51" muffler sounds pretty close to stock. Outside the truck it is a little louder, but inside it sounds quieter. Donaldson makes another 51" thats quieter then mine.
Old Apr 14, 2008 | 09:55 PM
C Schomer's Avatar
It's not worth changing the downpipe from the 3.5" unless he does a lot of engine mods. I put on a 51" Nelson when my engine was stock and it was slightly louder but it sounded like a trashcan so I stuffed the chambers with FG insulation and wrapped more around the outside. Then it was every bit as quiet as stock til I changed turbos. Then I got the drone thing and I put a resonator right behind the DP. It stopped the drone but it's still a little loud in the cab. Craig
Old Apr 15, 2008 | 08:45 AM
FSTDL's Avatar
Thanks for you help but does anyone make a bolt up replacement 4 inch system for his truck with out a strait through muffler?
Phil
Old Apr 15, 2008 | 08:47 AM
Hintz's Avatar
the stock system
jlambert
Oct 27, 2011 12:31 PM
6 Shaker
Oct 5, 2007 11:26 AM
1Thom
15
Sep 23, 2003 03:05 PM
shaft
Sep 1, 2003 03:37 PM
bdaniel
May 6, 2003 04:43 PM
