Quick Question: Torque Dog
Old Dec 5, 2006 | 04:57 PM
Patriot2500's Avatar
Anyone know if this has a built-in boost fooler? If it doesn't, could I hook the box up to the boost fooler and than plug the boost fooler into the MAP sensor plug? Would this work? I just installed my Quad fooler last night and am loving it. I am looking for a little more power and there is one for sale on the board that is at a good price. Thanks in advance.
Old Dec 5, 2006 | 04:59 PM
marc03's Avatar
Yes, it has one built in.
Old Dec 5, 2006 | 05:24 PM
SehrleBD's Avatar
The Torque Dog does have a built in Boost fooler. So no need to run the quad fooler.
Old Dec 6, 2006 | 06:41 AM
Thanks guys. Anyone running this on their 04.5? I am considering it because I want a little more power and maybe some more MPG.
Old Dec 6, 2006 | 09:47 AM
SehrleBD's Avatar
I wouldn't stack it with your Triple Dog you will lose right at 30hp
Old Dec 6, 2006 | 10:02 AM
I have the Power Pup, not the Triple Dog.
Old Dec 6, 2006 | 01:00 PM
SehrleBD's Avatar
You will still lose HP if you run the Crazy Larry with the Torque Dog. Because of the timing advance will be too much.
Old Dec 6, 2006 | 01:18 PM
Luken's Avatar
LOL you are joking right?
Please tell me you are not being serious...
Old Dec 6, 2006 | 01:34 PM
SehrleBD's Avatar
seriously there is horsepower lose with stacking the Torque Dog with Crazy Larry. On the timing advance im not sure but i do know for a fact that on a dyno if you stack a Crazy Larry anything with a Torque Dog you will lose about 30hp. The timing was about all i could figure it would be. Anybody ever stacked it on here with different results?
Old Dec 6, 2006 | 01:37 PM
CrashCade's Avatar
That is a common stack. Bully Dog even says you can run a 03 Torque Dog on the newer trucks. I have not tried the older set-up with it. I did Beta test a module for them which created too much timing and threw Cam/Crank performance codes under a WOT load but, never did I lose power.
Old Dec 6, 2006 | 01:45 PM
Luken's Avatar
Almost EVERYONE I have talked to that is running that stack gains 2-3 tenths in the 1/4 with the tq dog stacked.
I run a tst/bully dog. That stack does INSANE amounts of timing advance. I don't think I'm losing any hp. Just headgaskets LOL
Old Dec 6, 2006 | 01:46 PM
Luken's Avatar
With the bully dog/tst alone I dyno'ed the numbers in my sig. If I would've added pressure I think it would be a little higher.....
Old Dec 6, 2006 | 02:10 PM
SehrleBD's Avatar
Than I am sorry for being wrong Mister know it all.
Old Dec 6, 2006 | 02:29 PM
Luken's Avatar
Bob Wagner, The distributor for the Smartys called me "Mr. knowitall"
I think there is a limit to how much timing you can advance before things blow up but it really helps keeping the EGT's down and getting some more power.
No offense to ya man! I love my bully dog!
Lucas
Old Dec 7, 2006 | 11:38 AM
So I shouldn't have any problems stacking this with my PowerPup. I only run the PowerPup on level 2 (90hp) and have never turned it all the way up. If the Torque Dog is going to throw codes, then I am not going to buy it. I was going to run the Torque Dog on level 2 (50hp) all the time and turn it up to level 3 (90hp) when I feel like getting playful with the truck.
