Question for Those With Fuel Vent Relocation Kit
Old Nov 20, 2005 | 02:31 PM
Hoss's Avatar
Thats MR Hoss to you buddy!
I bought the kit from David Kelley and decided that I would put it on this afternoon. I read on here that the hardest part of the project was disconnecting the two quick connect fuel lines on top of the tank. I'm ashamed to say that I didn't even get that far.
The first step to this project is loosening the hose clamps and disconnecting the fuel and vent lines from the filler neck on the bed. After pulling and pushing and beating and then pushing some more for a full hour, I finally just tightened the clamps back up and put my tools away because I knew there was no way I'd finish in time for church tonight.
So, my question is, how did you guys get past that first step?? I'm not weak by any means, but those hoses just wouldn't budge. Any ideas??
-Frustrated Hoss
Old Nov 20, 2005 | 02:43 PM
BigBlue's Avatar
Sawzall works great. Try spraying some penetrating lube or something on there and letting it sit for a little while.
Old Nov 20, 2005 | 02:46 PM
Hoss's Avatar
You don't know how close I came to getting a saw out.
Old Nov 20, 2005 | 02:52 PM
JCROMAN's Avatar
-Frustrated Hoss
Just work a small flat tip screwdriver under the hose and work your way around it while twisting back and forth after loosening the clamps. it will eventually break free. make sure you loosen the clamps enough to slide them over the tube to make sure its not binding at all. then pull it off!!!
Old Nov 20, 2005 | 03:11 PM
BigBlue's Avatar
Wanna bet.
Old Nov 20, 2005 | 04:45 PM
TPilaske's Avatar
so now what's the purpose of this kit?
Tony
Old Nov 20, 2005 | 06:02 PM
siotwo's Avatar
Just wait until you try to disconnect the fuel lines. I breathed so much fumes (electricity was out so no fan, and 90+degree) I bolted the tank up and quit for the day. I'll try again someday.
Old Nov 20, 2005 | 06:17 PM
superman's Avatar
Tony
Not sure it will apply to the newer trucks with the in tank pump...but for those of us with earlier 3rd gens (and maybe even 1st & 2nd gens) fueling ALL the way up takes forever. The way dodge has designed these tanks the vent sits well below the highest point of the tank (most liekly for fuel expansion). So when you get to the 1st click of the pump...from there to actually fill the tank it takes another 10-15 minutes because of the foaming diesel fuel.
So with this vent kit it cuts your fill up times by nearly 70%...mine went from nearly 20 minutes to well under 8 to fill from empty. PLUS the tank now hold nearly 40 gallons. Some folks have worried about fuel expansion...BUT I live in florida and even on 100+ degree days after filling up and parking it...NEVER have I had fuel spill out and I fill it ALL the way to the vent tube where you can see the fuel.
Old Nov 20, 2005 | 06:21 PM
TPilaske's Avatar
Yeah.. it does take forever to fill my tank up... I too run it up to the vent in the filler... seems to get better (and more consistant) mileage that way.
Old Nov 20, 2005 | 06:36 PM
JCROMAN's Avatar
I have an 05 and yes its the same. i modded mine and now it takes less than 2 minutes to completly top it off after the pump kicks off.
Old Nov 20, 2005 | 06:38 PM
4x4not's Avatar
I'm about to do my vent kit tomorrow morning. I'll let you know how it goes
Old Nov 20, 2005 | 07:07 PM
MedicShawn's Avatar
With those electrical connections move the red slide and then squeeze the part of the connector farthest away from the pump. It says that in the directions but when you miss it re-reading them it's very frustrating.
Old Nov 20, 2005 | 09:44 PM
Hoss's Avatar
MedicShawn, I didn't get that far. I never got past Step 1 where you disconnect the fuel and vent line from the filler neck on the bed.
I'll try again in a couple of weeks after I run my tank back down. I was pressed for time today so I just quit.
Old Nov 20, 2005 | 09:48 PM
OOPS's Avatar
Silcone spray works wonders on rubber parts. Lift up the edge with a screwdriver and stick the straw in and spray. Give it a bit-o-time and it will slip right off and back on.
Old Nov 21, 2005 | 06:18 AM
TAS05CTD610's Avatar
Spray
The screw driver and spray works great. Also note at this part of the step to have somebody with you to clean your hand up, cause this is the part that most of use pull on the hose (with lots of force), it slips off extreamly easy and there's always a nice sharp piece of metal close to where your at, that your hand WILL find and you WILL hit hard. I found having somebody with a towel and gauze works wonders for not hurting yourself. Remember Safety first.
