Question about Smarty..
As of now i am running the superchips flashpaq on performance tune: Max 137HP and 282 foot lbs torque..
My question is if i got the smarty, which leve should i run it on to match this or do a bit better??
I'm also running the quadzilla boost fooler..
I also wanna try a stack out but i dont know which way to go, any help would be great..
Thanks..
Thanks..
With the 4.11 that would come loaded in it I would say an sw5 would feel the same. I know the smarty betas will seem alot hotter and the TNT is gonna knock your thing in the dirt. I dont think the superchips does anything to torque mgmnt or the top speed limiter does it. That makes the tuck really snappy.
I dont think the superchips has a top speed limiter, the truck tops out at 112mph i believe and as far as torgue mgmnt goes i have no clue.. The truck feels strong and pulls hard but still feels slow haha, i guess i'm just use to it..
I think it is Keiser Sose w/ a line above the 2nd S but who am I to judge? HAHA ! Trust me, #5(90 HP) on the Smarty w/ @ least mild TM will conquer the SC on what-have-ya'! If you run the 'stock injector/aftermarket turbo', you won't need the BF'er. If ya' wanna stack, get a Quad X2 w/ your Smarty+new BUILT tranny & you will be able to hurt somin'. Have fun w/yo' new found $$$$ pit, C'Muon!!!!!!!
I agree with what the others have already said. Software 5 will be at least as much, probably more then the superchip. You have a good list of mods already. A smarty will really wake that truck up.
Chris
Edited to add: Are you still running the factory in-tank lift pump?
Chris
I just ordered the Smarty, Fuel Boss fuel pump, and MK-2 filter kit from GDP. I highly recommned them, they have the whole package! The fuel Boss is a mechanical pump, never drops pressure. I am suppose to get mine in next Friday! IO highly recommend you check out the Fuel Boss, heard nothing but great things about it!
I looked into it and was considering it untill i saw this.. I have a Fluidampr..
Should i get rid to the Fluidampr and go back to stock in order to run the Fuel Boss kit??
**Note** Only for trucks with stock harmonic balancers. Due to dimensional differences this system will not work with aftermarket harmonic balancers such as the Fluidampr® brand balancers.
They are workin on a kit to keep the fluidampr witrh the fuel boss. I cant see how the fuel boss is gonna gain ya anything over the gdp or fass except less cashola in your wallet.
I have both and in the end I like the Smarty better. At first I didn't but thats cause I was runnin one of the older SC versions (more power than the updated version).
Long story short, the Smarty blows SC 's away.
skydiver41
03-23-2012 08:51 AM
stock03
34
04-21-2011 07:40 AM
jmccart
11-22-2007 07:43 PM
Mike Holmen
05-21-2007 10:21 PM
