Question about Quad boxes
I have a quad MM box on my 06 auto, 4x4. I bought a quad standard ( 65 ) box. The wiring harness ends are the same. My question is, can I plug the 65hp box into the mm harness? I know it will fit because I`ve done it with the engine off. My question is will it work right or cause a problem? I worry about doing anything that will hurt my truck as I work in this truck six days a week. My plan is to use the mm 90% of the time & plug in the other box when I need it. Any thoughts on this or should I just run the 65hp box all the time? Thanks & sorry for the long post.
Im not going to swear to anything because I would hate to cause you any problems, you might call quad after the week end, he might get online and see this and answer it, Im pretty sure the harness,s are the same, and you should be fine, but I would definately check with quad,
Thanks cowboy3600. I called Quad & they said both use the same harness. It seems ( I haven`t hand checked it yet ) that the standard box is getting better mpg then the mmm. It also seems to smoke less. I really can`t understand how I could add power & it do this but I`m not complaining!
Mocho
07-31-2008 07:00 PM
stock600
11-12-2007 08:45 PM
t-boe
01-04-2007 08:35 AM
