question
Old Dec 16, 2007 | 08:15 PM
francis's Avatar
Question question
i have a 03 dodge that has 35 12.50 18 on it and i am going to be putting the stock tires and wheels back on it. but i had a local dodge dealership program the computer to the tire size. am i going to have to take it back to the dealership for them to program it back to the stock tires or is there any other way i can do that,
thanks james
Old Dec 16, 2007 | 08:22 PM
vzdude's Avatar
DTR's 'Go to Guy'
Back to the dealer you go!
chipmonk's Avatar
thanks james
programmers like smarty or bully dog has a speedo correct- there are also some programmers that just do the speedo adjust for under $200.
Old Dec 16, 2007 | 08:24 PM
francis's Avatar
it will still over ride it on the computer when it says it has the 35 and i am going to a smaller tire
Old Dec 16, 2007 | 08:25 PM
chipmonk's Avatar
does he have to go back to the dealer since they've already changed it once? does the dealer adjust not let you use a programmer anymore?
Old Dec 16, 2007 | 08:27 PM
chipmonk's Avatar
so once the dealer adjusts, you can't use your programmer to change sizes until the dealer returns your speedo to factory?
Old Dec 16, 2007 | 08:43 PM
francis's Avatar
ok thanks for the advise dont wana pay for that again
Old Dec 16, 2007 | 09:20 PM
vzdude's Avatar
DTR's 'Go to Guy'
No.....you don't HAVE to go back to the dealer, but I believe most of the other programers are only good for one truck. Even if you only change tire size, that is the only truck you can have it on at that time. I could be wrong though. Maybe since you want to go back to stock, you can use a programmer to change the tire size once, then go back to stock and remove it. Worth a try if you have a friend that has one!?
Old Dec 16, 2007 | 10:50 PM
chipmonk's Avatar
nope- you're right. one programmer, one truck, one tire adjustment. it reads the truck by vin, so it would read as a vin mis-match.
Old Dec 17, 2007 | 08:55 AM
tslewisz's Avatar
Can you give examples of these?
Old Dec 17, 2007 | 10:59 AM
RamWheelsBy4's Avatar
I would have the dealer or someone with DRBIII access make the ABS "Pinion Factor" changes. My dealer is pretty good about this, did it free twice and charged me 1/2 hour tech time once ($37.50).
The programmers that will adjust the ECM ABS for correct tire size must be loaded on the vehicle. This will work as long as you keep it loaded. If you want to remove it for some reason they put back the value that was in the ECM when loaded.
I like mine to be correct with or without a programmer loaded. Just my .02.
Old Dec 18, 2007 | 06:34 PM
francis's Avatar
thanks everyone
Old Dec 18, 2007 | 06:50 PM
francis's Avatar
ram what dealership do you work at?
mkeanglorldo56
Nov 4, 2007 12:34 PM
Oval Racer
Jan 26, 2007 02:57 PM
8mpg
May 8, 2006 06:37 PM
donhov
Dec 13, 2005 01:48 PM
