Quadzilla Switch mount
Old Oct 3, 2006 | 07:35 AM
Knuckle Head's Avatar
Looking for ideas/suggestions on where to mount the switch for the Xzillirader module. The directions say not to mount it under the steering column which is where I had planned on mounting it. Thanks
Old Oct 3, 2006 | 08:18 AM
qzilla's Avatar
You can actually mount it anywhere you want. We just wanted to warn people before they go drilling a hole that the panel under the dash is really too thick as it consists of 2 pieces of plastic mated together.
if you want to spend the time you can make it work. You will need to drill your hole and then you will need to chip the plastic off of the back side somehow so that it is only as thick as a single piece of plastic.
Quad
Old Oct 3, 2006 | 08:31 AM
JThiessen's Avatar
Underneath the cup holder (in models with the fold down cupholders), there is a removable bexel about 3-4" tall. I put mine in the lower left hand side of it.
Old Oct 3, 2006 | 08:59 AM
yfz450guy's Avatar
just set it on the highest level and tuck it up under the dash.
Old Oct 3, 2006 | 10:37 AM
05HDRAM's Avatar
I did the same.
Old Oct 3, 2006 | 11:38 AM
2005 CTD BEAST's Avatar
Mine is under the E-brake lever.
Old Oct 3, 2006 | 01:01 PM
973604x4's Avatar
my EZ switch was on the under side of the steering column totally out of sight. people in the truck can only hear the click when i would change levels.
Old Oct 3, 2006 | 01:04 PM
jaredb900rr's Avatar
I thought it would be cool to put it where the cigarette lighter is near the right side of the steering wheel. Have it on a push in / pull out spring sort of assembly. And then modify the actual cigarette lighter to go over the switch so it would be hidden. Anybody have any good ideas how to do that?
Old Oct 3, 2006 | 01:31 PM
dodgezilla04's Avatar
i popped out my cig lighter. made a 2 piece collar to mount it to out of stainless. takes about 2 minutes to remove it and put the lighter back if I had to.
Old Oct 3, 2006 | 02:14 PM
Switch Mount
I think the area under the cup holder sounds the best, I will take a look at it tonight when I get home.
Thanks for the help!
Old Oct 3, 2006 | 02:17 PM
Forgot to add, some body stole my drills, both my electric and the cordless, left the charger though and other tools, strange huh!
Old Oct 3, 2006 | 02:55 PM
ptgarcia's Avatar
I have an '06 so the dash is a little different than yours, but I mounted mine in a switch blank:
Old Oct 3, 2006 | 03:34 PM
NB64's Avatar
This box is installed with velcro no holes drilled, easily removed.[IMG][/IMG]
Old Oct 9, 2006 | 07:57 PM
hic316's Avatar
mounted mine right behind the tilt lever on my 2nd gen, and will put led's up on dash above steering wheel to know position.
J10495T
Sep 21, 2011 04:07 PM
chw
Dec 25, 2006 04:30 PM
fade94
Oct 16, 2006 12:48 PM
mxboy
Mar 15, 2005 12:23 PM
12valve@heart
Aug 11, 2004 03:43 PM
