Quadzilla Standard problems
Old Feb 8, 2007 | 12:50 PM
bocuso's Avatar
I recently had my quad do something funny. I was playing around the other day with the box set at 100 and going WOT when I let off the accelarator, the engine redlined.
Has anyone else hda this happen?
This is the first problem I have had with the box.
Old Feb 8, 2007 | 01:19 PM
Dodgezilla's Avatar
Mine does it anytime I quickly rev up past 3000 rpms. I was told it's normal. I try to tailor my driving habits around it and I rarely have it happen anymore....
Old Feb 8, 2007 | 02:02 PM
qzilla's Avatar
You have to realize that when the rail pressures up to 23-24-25-26K it takes it a second to de-pressurize. If you beat on the truck stock you will be able to notice this but, it is definately enhanced by a power module.
It is worse at redline if you jump out of it but if you stab the throttle hard in a parking lot and then jump on the brakes you will see the same sort of behavior, stock or modified. It is sort of a thing with Common Rails.
steelblitzkrieg
Jun 26, 2007 11:03 AM
Jmac
33
Apr 15, 2007 01:28 PM
jon05ctd
Dec 31, 2006 10:04 PM
Batts
13
Jun 2, 2006 02:35 PM
JIMCTD
Oct 16, 2005 03:39 PM
