Quadzilla engine missing?
Old Oct 8, 2005 | 03:10 PM
05dodgezilla's Avatar
when on level 4 (130 hp) on the quadzilla race box there seems to be a engine hick-up or maybe a fueling problem just happens on the high settings. Just wanting to know if anyone else has had this problem or any other problem out of the q-race box thanks!
Old Oct 8, 2005 | 04:42 PM
swansong04's Avatar
well, i have the 65-hp towing box from quad and it still does this after i sent it back to them 80( it makes really nice power , idles nicely , but when under load , going up a hill at about 2200rpm in tow/haul mode and at big time WOT for instance when going on to the freeway it surges like crazy .. quad said they didnt find a problem with it but did do a re-flash of the box . but still no luck .. but like i said it still makes really nice power but with a surge...
Old Oct 8, 2005 | 06:34 PM
PourinDiesel's Avatar
I have a miss also when I turn my TST box all the way up under wide open throttle conditions.
I am going next week probably to see if I have a bad harness?
Maybe a reflash will help.
I feel your pain!
Old Oct 8, 2005 | 07:17 PM
i have read from some other post that sugest it might be getting too much fuel but i don't think thats the case no smoke just hick-ups hmm..... any advise?
Old Oct 8, 2005 | 09:41 PM
rich2500's Avatar
how about lack of enough fuel
Old Jul 26, 2006 | 08:24 AM
bcrb's Avatar
05dodgezilla did you ever get this cleared up with quad. Let me know mine is also doing the exact same thing
Old Jul 26, 2006 | 08:41 AM
Dodgezilla's Avatar
I would also suggest that it's a lack of fuel causing this. My TST does this too when I turn it up too high but I was told in advance that it would happen. You may benefit from one of the aftermarket lift pumps like a FASS or Walbro system.....
Old Jul 26, 2006 | 08:54 AM
bcrb's Avatar
do you think that this chip is dumping enough fuel to cause the pump to not "keep up"
Old Jul 26, 2006 | 09:43 AM
Dodgezilla's Avatar
It's possible on the high setting. If it's happening on the lower settings then you have some other issue... I never had a problem until I started stacking boxes but my stock LP would drop to 0 psi on a hard pull.....
Old Jul 26, 2006 | 09:46 AM
ptgarcia's Avatar
I'd say it's definately a possibility, especially when floored while on the 140 h.p. setting. I would add a fuel pressure gauge to see whats going on when it starts to surge.
Old Jul 26, 2006 | 10:59 AM
bcrb's Avatar
hey thanks guys I will go get a fuel pressure guage thanks for the response to my problem. Hey dodgezilla did you ever stack anything with your quad race box.
Old Jul 26, 2006 | 11:08 AM
Dodgezilla's Avatar
Van Aaken C3.2 Duration box... Very nice power, lots of black smoke, and with the stock turbo my temps stayed well in check. Once I got the HTB2 turbo my temps shot up to 1500+ degrees on a hard pull. I thought it would be the opposite but I guess the extra air allowed for a lot more fuel. Bottom end was more powerful than my current stack but the top end wasn't as good as I have now. If not for the high temps, I would still run that stack....
mopar440cu
Nov 21, 2015 08:39 PM
DodgeRamdiese01
Sep 15, 2009 08:28 PM
norcaljr
13
Aug 5, 2008 10:13 AM
Smokin98.5
0
May 29, 2008 05:35 PM
hvanflee
Nov 27, 2003 03:05 PM
