quadzilla camander
Old Dec 21, 2007 | 08:40 PM
turbotowrig's Avatar
quadzilla camander
i have the quadzilla guage thing. and it has been working good for a few months, but recently, the water temp has been jumping around. it runs at about 189* but its been just jumping to 233* randomly. and the stock temp guage is still int he same spot, so im pretty sure my truck isnt running hot. any idea how to fix this.
Old Dec 21, 2007 | 08:58 PM
EDR's Avatar
EDR
The most likely cause and easiest to fix is the connection. If it's worked until now the connection may have just come loose. If I remember correctly, the fiber washer needs to be in the right position for the sensor readout to work properly.
I had a similar problem with my water temperature read out recently. I resecured the electrical connection and it solved the problem.
Good luck.
Old Dec 22, 2007 | 07:15 AM
Hunter11's Avatar
I had a similar problem a couple of weeks ago. I changed oil about that time and the water temp was all over the place the next day. I guess while changing the oil I hit the connection at the temp sender and was getting a intermittant reading. I fixed the connection and all is well again.
duallydave
Jun 29, 2012 03:17 PM
duallydave
Apr 9, 2008 09:45 AM
duallydave
Apr 3, 2008 06:51 PM
duallydave
Mar 31, 2008 12:47 PM
duallydave
Mar 25, 2008 03:18 PM
