couple of camander questions???
Old Mar 23, 2008 | 12:46 PM
duallydave's Avatar
i bought a used camander some time ago and finaly got around to installing it,seemed pretty straight forward,questions are,,i am running a x2 race box and i conected it to the camander so i know i will only have 3 levels to choose from,i conected the boost wire from the camander to the wire on the factory boost conector not the one from the x2,is that corect to get the non fooled level?can the purple wire for the trans temp be used for engine oil temp?i have a stick so i dont need the trans temp,i also have the fuel presure kit but cant find any instructions on installing that on the site,thanx
Old Mar 23, 2008 | 12:57 PM
Justice4all's Avatar
You need to connect the boost lead to the boost wire on the Quadzilla harness. You want to read the fooled boost amount, otherwise you will not see what your turbo is producing with a disabled wastegate. I have an electronic version of the FP kit instructions. I will gladly send them to you if you PM me with an e-mail address.
Old Mar 23, 2008 | 05:31 PM
BossHogg's Avatar
the customer service is pretty good too, you could call and talk to the tech.
Old Mar 23, 2008 | 05:39 PM
Seeder's Avatar
If you are running the X2 box with the commander I believe Quad has an update for the commander so you can run the five levels instaed of the 3 levels the commander was originally designed to run.
-Seeder
Old Mar 24, 2008 | 09:08 AM
duallydave's Avatar
i have the pod that came with the x2 and the boost numbers seem the same on both so it must be in the rite spot,does the camander read rail presure in its stock form?my pod reads rail pres so i disconected the pod and plugged the x2 into the camandet and chose rail pres as a disply but nothiing shows up,also can the camandr read engine oil temp,if so where do you conect the purple wire too,thanx guys
Old Mar 25, 2008 | 09:06 AM
CTD NUT's Avatar
Yes, the Commander will read RP. It will plug into the X2 harness at the rail pressure sensor. You might have to go into the set up menu and make sure it is turned on too. Also, the purple temp wire and sender will thread into one of the 1/8" NPT ports in the top of the engine oil filter head. I did the exact same thing to mine since I also have a stick. It works fine but you will have to lengthen the purple wire a little bit to reach over to the passenger side of the engine.
Old Mar 25, 2008 | 10:15 AM
duallydave's Avatar
thanx for the info,i conected the x2 to the camander but the camander plug only has a blackand white wire on the conector and the x2 plug has 4 wires,do i need the special adapter from quad to get the camander to read rail pres?the pod reads it but it has 4 wires too,also to get the engine oil temp do i need a sender of some kind?i bought this camander used and it didnt come with any senders,thanx for the info so far
Old Mar 25, 2008 | 10:26 AM
welndmn's Avatar
The Commander will only read Fuel/Rail pressue if you bought the Fuel Pressure kit (sold Seprate)
Old Mar 25, 2008 | 11:01 AM
CTD NUT's Avatar
Correct....I forgot to add that. You will need the #CCSFPKIT fuel pressure harness kit for the Commander if you don't already have it. This allows the Commander to plug into the X2 rail pressure sensor harness and also includes a lift pump pressure sender and harness. If you do not have this kit, you will ne be able to read rail or LP pressures.
There is a temp sender included with the Commander for reading trans temp.....this sender can also be used for engine oil temp. If you don't have that you should call or email Quad to get that. Sounds like you might need to get the fuel pressure kit from them anyway.
The black and white wire from the Commander allow it to control only the top 3 power levels from the X2. Quad has just come out with a new harness adapter and Commander software update to allow it to control all power levels from the X2.
Old Mar 25, 2008 | 01:41 PM
duallydave's Avatar
so without another harness the camander wont read rail pres?the pod does and i figured if i unplged the pod and pluged the x2 into the camder it should read it too,can i get a temp sender from a local auto shop?or is it a special thing.i live in canada and ive had lots of issues shipping stuff across the border,thanx for info so far
Old Mar 25, 2008 | 03:18 PM
CTD NUT's Avatar
I hear you on the cross border shipping issues. Yes, you could very well get the temp sender locally but I do not know the resistance values it is intended to operate under. A call to Quad might clear that up. As to rail pressure, I thought the FP kit harness included the rail pressure lead but now I'm not 100% sure. I installed the X2, Commander and fuel pressure harness kit all at once so I could be wrong. I thought the kit was to allow the Commander to read both pressures.
duallydave
Apr 10, 2008 10:23 AM
duallydave
Apr 9, 2008 09:45 AM
duallydave
Apr 3, 2008 06:51 PM
duallydave
Mar 31, 2008 12:47 PM
turbotowrig
Dec 22, 2007 07:15 AM
