fuel kit harness question,camander???
Old Apr 2, 2008 | 12:49 PM
duallydave's Avatar
i recently installed,the fuel kit for my camander,everything seems to work,injection presure is the same as the pod on the x2,i guess it should be as they both get the readings from the same spot,my fuel pres seems high,it goes to 18psi upon startup and then to 20-21 after warmup,i have the lp in tank done as a factory waranty issue,with the pred on rkl no timing i can only get her to drop to 14psi,is that normal for a factory lp,when the quad senders fail like i read some do,do they fail in high readings or low?also what does the extra conector on the fuel harness conect to?the one 4 pin conects to the camader and theres a 3 wire one left over,has a blk and white and red i think,cant remeber if its male or female i just dont know what its for,thanx for any info
Old Apr 3, 2008 | 06:51 PM
duallydave's Avatar
bumppppp any info??
duallydave
Apr 10, 2008 10:23 AM
duallydave
Apr 9, 2008 09:45 AM
duallydave
Mar 31, 2008 12:47 PM
duallydave
Mar 25, 2008 03:18 PM
turbotowrig
Dec 22, 2007 07:15 AM
