Quad When ?
Originally Posted by qzilla
That totally depends on what you are looking for. There are several things that will be coming out soon. The monitor is first, then we have multiple modules trickling out after that.
MikeyB
Timing box is coming.
The box to compete with TST, well maybe. The problem is that unless you are drag racing or dynoing the downside to duration is hard to overcome.
We have it all working and man you sure can make some power, but the egt's are just out of control.
On a dyno the duration works really well, but I am not sure that is the best thing for everyday use or even for drag racing. With that said some duration is desirable.
You will see something from us, but it will most likely be for drag racing only and won't be available for a little while. I love drag racing and I know on the forums the power numbers are a big deal, but we typically cater to those with mostly stock trucks. If we release something like that it will tear up transmission, turbos etc.
Now, you will see something in the 160hp range that has very cool things on it in May or so.
Quad
Quad
LbZ, LLY and LB7 XZT are basically done. We will most likely only build the Xzillaraider for the LB7. Our Stealth 2 for the LB7 and LLY is a pretty awesome product already. Just FYI they also do Real Time Data Monitoring now.
We also are basically done with the 98.5-02 Comp Killers....did I say that? I mean the Xzillaraiders and XZT boxes.
March, April and May are looking to be pretty ridiculous for us. I am not sure how all the projects came to a head like they did, but it is a little hectic around here!
While we are in the subject I will try to make the list easy to read
Monitor - March 1st - backorders start shipping.
Monitor - April 20th - as of today the backorders should be filled at this point and production shouldcatch up
Xzillaraider and XZT 98-02 24v - March 17th or there abouts released. Backorders expected to be filled by April 1st. Most of our distributors don't know we built this yet!
XZT - DMAX 01-06 - April 1st including LBZ
Stealth 2 LBZ April 1st
Xzillaraider LB7 - April 15th 100hp
Timing Only Dodge 03-06- May 1st
X2- Dodge 03-06- May 15th
X2 6L Ford 03-06 June 1st
X2- 03-06 Dodge-RACE ONLY- Mid Summer if we continue
Busy, Busy, Busy!!!!
Stay tuned for more info on the X2. It has some pretty cool features and a pretty cool price for the features offered.
MikeyB
89dieselkong
Jul 27, 2010 10:55 AM
P.J
Oct 13, 2006 01:54 PM
hllbllyhellion
Aug 19, 2006 06:18 AM
