Quad Rail Pressure Guage......
Old Jul 13, 2007 | 03:28 AM
  #31
dieselfite's Avatar
Originally Posted by 03qclb5spd
Uh oh! I have a Jake I was thinking of putting on.....
You can still do it I know on my 06 I am tapping itno the bottom of my fuel filter canister.
Old Jul 13, 2007 | 03:09 PM
  #32
jwb600's Avatar
I installed my gauge today it was pretty easy just all plug in stuff. the large ring terminal ground cable goes into the cab, the smaller one is for the fuel pressure gauge which I cleared that up by calling the quad help line. didnt wait long and nice guy on the line cleared it up for me fast. I got it installed and I like how it has the dimmer button on it. Im pleased with the product. I think my rail pressure is a little low, but the gauge is a nice & compact. its what I needed
Old Jul 13, 2007 | 06:02 PM
  #33
Dodgezilla's Avatar
There are a couple of ways to raise that pressure if you think it's low.....
Old Jul 13, 2007 | 09:49 PM
  #34
03qclb5spd's Avatar
I agree. I took my time and had it done in about 20 minutes or so. I like the guage, color is pretty nice but I wish the wire from the gauge was black, not grey. I hid as much as I could behind the steering column, but an inch or two still shows. I thought about a little electrical tape but I think it might be tacky, plus elec tape seems a little glossy sometimes....I have some flat black paint I might try out to help "hide" the wire.
Well, elaborate zilla!
Old Jul 14, 2007 | 10:58 AM
  #35
Dodgezilla's Avatar
I was referring to adding a pressure box...
I got mine installed today in about 25 minutes. I haven't really driven it much but the highest pressure I saw on a quick hard pass was around 23,000psi. It idles right at 9000psi too. I'll get more readings in the next couple days....
Old Jul 14, 2007 | 12:48 PM
  #36
jwb600's Avatar
[QUOTE=03qclb5spd;1597901]I agree. I took my time and had it done in about 20 minutes or so. I like the guage, color is pretty nice but I wish the wire from the gauge was black, not grey. I hid as much as I could behind the steering column, but an inch or two still shows. I thought about a little electrical tape but I think it might be tacky, plus elec tape seems a little glossy sometimes....I have some flat black paint I might try out to help "hide" the wire.
adam my truck has tan interior so I know how you feel. I dont worry about it. its kind of a grayish mix on the gauge, but most dodges have black or gray interior not tan. I stuck mine on over there under the the headlight switch like we talked about.
Old Jul 14, 2007 | 12:50 PM
  #37
jwb600's Avatar
about the same pressures here. it drops down alot more when my tst is on. I do have a stage 2 cp3 also. I am looking into getting a pressure box. just trying to find a deal on an mp8 somewhere
Old Jul 14, 2007 | 02:33 PM
  #38
Dodgezilla's Avatar
There's one in the classifieds here for a very good price...... I just saw it this morning.....
Old Jul 15, 2007 | 04:28 PM
  #39
sqrl$$'s Avatar
Just ordered mine today!
Old Jul 15, 2007 | 06:48 PM
  #40
Dodgezilla's Avatar
I turned the Puck on along with the regular Extreme tune on my Predator and the rail pressure jumped 3000psi to over 26000.........
I like this new guage......
Old Jul 15, 2007 | 07:00 PM
  #41
rustyshakelford's Avatar
i had to unhook mine. somethings not right with it and it made my truck run like poopoo for some reason. i guess i need to get in touch with quadzilla and see about sending it off!! at idle it would be very rough and the rpms would be from 500-800 back and forth then on the highway sometimes it would just loose power. i unhooked the rp part and its running normal again. i need to take the fp sender off the fuel filter canister, but i think my LP is toast and im worried i wont beable to fill it back up with fuel???
brett
Old Jul 15, 2007 | 07:05 PM
  #42
Dodgezilla's Avatar
That's odd. Sounds like a bad wire in the harness connecting to the rail....
Old Jul 15, 2007 | 07:06 PM
  #43
i dont know. its weird. sometimes it runs good, other times not so good. its fixing to go into the shop for injectors and lp ...
brett
White97GTVert
19
Mar 18, 2008 03:03 AM
qwkness
31
Oct 5, 2007 10:57 PM
out4elk
20
Aug 26, 2007 12:53 PM
jgiachino
Jul 23, 2007 04:29 PM
trik396
Jun 14, 2007 05:41 PM
