** Quad rail guage came with CCSFPKIT for fuel pressure.. wrong?
Old Mar 14, 2008 | 10:56 PM
White97GTVert's Avatar
Okay so I ordered my Rail Pressure Gauge from XTREMEDIESELPERFORMANCE (XDP). They said the regular fuel pressure senders are discontinued and said they would send one for a commander that will work.
They did. The box says "CCSFPKIT" and below it says 6.0 Ford.
I checked the part #'s on quads site and they seem to be the same. How does this work on the dodge? i don't understand how this will interface with the banjo bolt on the CP3?
Its a bulbous shaped fuel pressure sender and an l shaped thing made up of a bunch of different fittings.
Can I make this work? I am a little annoyed if they sent me the wrong dang part.
Can the fuel pressure module be threaded into the bottom of the filter housing and and not worry about the banjo bolt issue. Or can someone please explain how I would make it work with the CP3 banjo fitting.
Unfortunately I can't get you all a picture at the moment.
Is this a universal kit (CCSFPKIT)
Thanks! Quad please help!
Old Mar 14, 2008 | 10:58 PM
Cummins610's Avatar
Should of got it from larry.....Quad FP kit is a nice piece
Old Mar 14, 2008 | 11:07 PM
Despite where I got it (somewhere that took my AMEX)
Do you have any input on the CCSFPKIT model? It is also listed under Dodge parts on the Quadzilla site. I just don't see the banjo fittings.
Can I screw the sender directly into the bottom of the fuel filter housing instead of going int he CP3? Will that work?
Any help appreciated.
Thanks!
Old Mar 14, 2008 | 11:20 PM
53 willys's Avatar
If I am understanding this right all you need is this.......Right???
Old Mar 14, 2008 | 11:28 PM
Mark you are probably right. Where can I get on of those.. Like tonight or tomorrow. I am installing all this stuff tomorrow and want to make sure I get it all done the same day.
Any ideas (farm shops, dealership, etc)
Thanks!
Old Mar 14, 2008 | 11:34 PM
53 willys's Avatar
Thanks!
I could get you one...but no way I could do it by tomorrow....is there any diesel performance shops by you??? isn't Rip source up there in WA??I don't think those banjos are something a local parts store would carry....somebody up there must have one...it might be hard on a Saturday tho....sorry I guess I am not much help
Old Mar 14, 2008 | 11:36 PM
Rip is down south about 160 miles from here. Bit of a drive. I guess its not THAT important (to drive 320 miles to get one). . I thought I read somewhere there is a fitting this could thread into on the bottom of the filter assembly on the engine.
I'll have to keep searching.
Thanks for the ideas though!
Old Mar 14, 2008 | 11:42 PM
53 willys's Avatar
if you have the tools you could maybe tap your stock bolt to get you by???
Old Mar 14, 2008 | 11:45 PM
Tap my own bolt...
Yes I supposed that is an option. I have the drill press but not sure if I have the tap/die. I'll have to look.
Do you know anything about the fitting on the bottom of the factory fuel filter housing? Is it a banjo as well?
Old Mar 14, 2008 | 11:47 PM
tristan21's Avatar
Check for a hyspeco or parker high preassure hose store close buy. You can get it from about anybody that deals in hydrolic repair hoses and parts.
Old Mar 15, 2008 | 12:24 AM
53 willys's Avatar
my stock fuel filter housing had banjos on it as well....inlet and outlet are banjos...
Old Mar 15, 2008 | 07:09 AM
sallyman1's Avatar
i just ordered a quad rail gauge and LP kit from the DTR store? will i get same results? will i get a good one updated one? is the store on this site good?
Old Mar 15, 2008 | 02:14 PM
No I'm sure you will get the right parts. It was a mistake on XDP's part. No worries for you!
Old Mar 15, 2008 | 07:46 PM
mattf's Avatar
dynomite diesel is in monroe, that isn't more than an hour or so is it?
Old Mar 16, 2008 | 12:20 AM
lesimon's Avatar
Just to let you know that if you drill and tap the stock banjo bolt that it will not be be very strong I looked at that option. I ended up purchasing a banjo bolt from a Dodge dealer and welded on a 1/8 hydraulic threaded coupler, worked great and is strong. I did the same thing for the boost bolt. I was unable to find anyone in British Columbia, Canada that could supply these bolts/fittings. Good luck with your install.
