quad race & rokktech, too much?
Old Nov 27, 2005 | 06:58 PM
oxman's Avatar
After installing box, I notice a loud ticking at idle, mostly when the truck is cold, is this due to too much timing advance? I was going to back off the sensor some but figured I'd ask beforehand. Truck seems to run fine but seems/sounds a little much too me. I know rokktech site says it works but wondered what ya'll though?
Old Nov 27, 2005 | 07:26 PM
catdiesel's Avatar
Mine ticks at idle when its cold out as welland its stock
Old Nov 27, 2005 | 07:29 PM
mikmaze's Avatar
pfffft central FLorida "cold" engine roflmbo..... that engine knows not what cold is....... afew are running roktech and quad boxes with no troubles.. if I ever get my but under my truck I will have the tone ring mod too and the quad box.
Old Nov 27, 2005 | 07:43 PM
oxman's Avatar
I was referring to "cold" in the sense of a motor that has not reached it's operating temp, not the outside temp. Obviously central florida is a much warmer climate than you guys above Tenn. The ticking goes away after 5 mins or so. I'll adjust the rokktech tomorrow and see if it helps.
Old Nov 27, 2005 | 07:47 PM
catdiesel's Avatar
I personally dont think the ticking has to do with the timing. Mine is BONE stock and it does the ticking as well when the engine is cold. But it runs PERFECT.
Old Nov 27, 2005 | 07:51 PM
jthorpe's Avatar
DTR Founder
Mine does the same thing, and it's stock too.
Old Nov 27, 2005 | 08:59 PM
runamuk's Avatar
I have the same thing! Welcome to the world of diesels!
I've narrowed it down to the normal sound of the injectors.
Rick
Old Nov 28, 2005 | 06:59 AM
SolarRam's Avatar
I have the Rokktech and the BDTD and have the same noise, the truck runs fine though so I have not messed with it.
Old Nov 28, 2005 | 07:20 AM
wap's Avatar
wap
For those of you running the rokktech and quad (or any other chip for that matter) was there a noticable improvement in power or fuel economy over just the quad or what ever chip you are running? Also isnt the rokktech and tone ring mod the same thing?
Old Nov 28, 2005 | 07:32 AM
oxman's Avatar
Yes the rokktech and tone ring do the same thing in the end. I had the sensor before the box. Truck didn't make noise before box which is why I thought the timing was a little high
Old Nov 28, 2005 | 07:41 AM
Reel Native's Avatar
Oxman, dont have an answer for you but it's good to know someone else here is from central Florida.
Old Nov 28, 2005 | 05:05 PM
supercharger's Avatar
Somtimes they tick other times they won't. More noticable cold but, will do it warm sometimes too. No need to worry 55k on mine ticking since new. Mine usually lasts 3 min on average when engine is cold.
Old Nov 28, 2005 | 07:09 PM
SolarRam's Avatar
Mine ticks all the time now.
I have not noticed any mileage improvement with the Rokktech.
QWKSLVRZ06
Nov 26, 2011 02:59 AM
BigJohnston
Feb 7, 2008 06:14 AM
duallydave
Aug 16, 2007 04:13 AM
06megacabman
Jun 11, 2007 12:11 AM
03CumminZ4X4
Jan 16, 2006 10:11 AM
