Quad Commander Wiring Question for 06's
Old Jun 21, 2007 | 07:03 PM
06CTDforAU's Avatar
I've got a Commander soon to be on it's way to me and I have a question about the wiring. I have everything covered except for tapping into the ECT sensor on the engine. Quad's manual states to use a multi-meter to find the correct wire, but I don't have a multi-meter right now; my Fluke meter died a few weeks ago and I haven't had a chance to pick another one up. Can anyone with an '06 model help me out here? I just need to know which wire to tap into. Any help would be greatly appreciated.....
I also still have my previous gauge setup for sale if anyone is interested. ISSPRO 3 gauge pillar kit with pyro, boost, and trans temp; It's all less than a year old and in perfect condition. Contact me for more information if you are interested.
Old Jun 21, 2007 | 07:20 PM
Luvnacumns's Avatar
Here's a pic for ya..
Shane
Old Jun 21, 2007 | 07:31 PM
ptgarcia's Avatar
I didn't have a multi-meter at the time either, so I just tapped the wire the directions said to tap (from the directions: "pin B as labeled on top of the connector.") and it worked great.
Old Jun 21, 2007 | 07:58 PM
shortbed rv's Avatar
Do you have an old 12 volt test light. It should light but it would not be very bright.
Old Jun 21, 2007 | 08:32 PM
06CTDforAU's Avatar
shortbed..... come to think of it, I do have a test light somewhere around here. I didn't even think about that. Good idea.
Luvn..... that pic is worth a 1000 words.
pt..... I guess I should have read the manual again. I just read it again and now I see where it says "pin b".
Thanks guys!
Old Jun 21, 2007 | 08:34 PM
Luvnacumns's Avatar
Thanks guys!
Tell me about it!! It took me forever to find a multimeter!!! Glad I could help!!
Old Jun 21, 2007 | 08:43 PM
06CTDforAU's Avatar
Also a couple other things.... did yall connect the power wire to fuse #28 as the manual instructs me to do? I wasn't sure if it was the same fuse on all model year trucks. I know the fuse panel seems to be a little different on the 06-07 models compared to the 03-05. I already have a Pyrometer probe installed that I used with my anlog gauges. It should back out pretty easy right? I shouldn't have to drill and tap a new hole should I? I would use the same pyro but it looks like the Quad pyro uses weather-pack type connectors and the pyro I have installed uses regular terminals and shrink wrap. Sorry for all the questions. I want this install to go as smoothly as possible......
Old Jun 21, 2007 | 08:45 PM
Luvnacumns's Avatar
Yes it should just back out and put the other one in..
Old Jun 21, 2007 | 08:47 PM
06CTDforAU's Avatar
Thanks for the info. That was what I was hoping to hear. How about the fuse? Is #28 correct?
Old Jun 21, 2007 | 08:48 PM
Luvnacumns's Avatar
Yes sir!!!!
Old Jun 21, 2007 | 08:49 PM
06CTDforAU's Avatar
Good deal. I think that'll be all I need for this install. Thanks for the help guys. I sure do appreciate it.....
Old Jun 22, 2007 | 10:22 AM
JThiessen's Avatar
You'll have to dremel out a little bit of your fuse box lid to get the wire out of the fuse box.
Old Jun 22, 2007 | 10:28 AM
06CTDforAU's Avatar
Good point JT. I didn't think about that. I've got a dremel @ the house so that shouldn't be a problem at all. Thanks for the info!
stock03
Nov 9, 2006 11:27 PM
carcrz
Nov 9, 2006 01:26 PM
jaredb900rr
38
Nov 6, 2006 12:09 PM
skydiver41
Sep 1, 2006 11:53 PM
HDBeauty
Aug 26, 2006 09:24 PM
