Which Quad box or programmer?
Old Oct 20, 2006 | 04:43 PM
dodgezilla04's Avatar
as soon as I swapped the turbo and put on the bigger tires, the clutch just died a slow death.
Old Oct 20, 2006 | 04:44 PM
overcomer401965's Avatar
I wont be doin any stakin
Old Oct 20, 2006 | 04:57 PM
What does the standard box do
Old Oct 20, 2006 | 05:02 PM
ptgarcia's Avatar
The standard box is 30-60-100. I run the standard with the Commander and its perfect for me. Gives me plenty of power (I have it set on the 60 hp setting day in and day out) and I don't feel like I'm going to destroy anything. I also towed with it off because I didn't have the Commander installed. Now that its in I'm dying to hook up and see which setting I can use to tow. My load usually weighs about 10,000 lbs.
Old Oct 20, 2006 | 05:12 PM
Standard sounds like the one for me. Does it still do pressure?
Old Oct 20, 2006 | 05:17 PM
yes still does pressure. too bad you are too far away, I'd let you try mine. quad is in texas somewhere, are you close enough for a visit?
Old Oct 20, 2006 | 05:30 PM
Where in Texas?
Old Oct 20, 2006 | 05:59 PM
goose2's Avatar
Originally Posted by dodgezilla04
fuel pressure, boost fooling, timing, duration. the standard is stock, 30, 60 and 100hp. the race is stock, 30, 60, and 130+hp.
I think that if you look into the race module. It is 60-100-130. Not 30-60-130.It was my understanding that the race module did away with the 30 hp. I could be wrong though.
Old Oct 20, 2006 | 06:13 PM
boostjunkie1's Avatar
What is an Unsafe pressure for the Stock Truck????? 03-06?????
Old Oct 20, 2006 | 07:59 PM
Dixie Chopper's Avatar
I hooked up my race box last night and of course, what do I do but turn it on 130hp and do a ~8psi launch. The thing is scary fast, but what scared me was the sound coming from what sounded like just on the other side of the firewall under my feet. Sounded like clatter or something. Any way, I backed it down to 100 and it sounded a lot better but a little less pull.
On 100 & 140 I was hittin 42-44 psi and 1300-1400 though.
silkywoods
18
Mar 2, 2008 08:14 PM
ib516
17
Aug 16, 2007 09:26 PM
toupee
Jun 7, 2007 08:54 AM
bubba001
Mar 7, 2007 08:58 PM
imfletcher
15
May 12, 2006 08:31 AM
