Qaudzilla Recon XZT
Old Jan 23, 2008 | 03:20 PM
alseman's Avatar
Question Qaudzilla Recon XZT
I have a 2004 dodge 5.9L. Does anyone have the Quadzilla Recon on there truck? If so how do you like it, and is it worth it?
Old Jan 23, 2008 | 03:28 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
Yeah, I'm using one right now. It's a pretty good little monitor. Is it worth it? Of course it is. It's easy to read, easy to hook up, easy to use and has some great features. Like warning when you exceed a certain preselected level on all of the parameters. If you're monitoring the EGT and you exceed the the boost value you set, the Recon will automaticly flash the exceeded value. And it will store those values for you to check when you stop.
The only issue I have is that it shows only one parameter at a time. In order to go to another parameter, YOU have to push an easy to use button. Personally, I like to look once and see all of my gauges at once. So, I'm in the process of switching to Isspro Gauges. But make now mis-stake, this is a really good monitor system.
Old Jun 4, 2008 | 12:46 PM
dodge_24's Avatar
are u selling the recon
need for fuel press
Old Jun 4, 2008 | 01:12 PM
PEAKSTRYDE's Avatar
The fuel pressure gauge uses the recon housing but I believe is a totally different unit.
Old Jun 4, 2008 | 01:23 PM
JPR Ram's Avatar
Actually, the RECON can also be upgraded to replace the Transmission/Oil Sensor for a Fuel Pressure kit.
Old Jun 4, 2008 | 01:24 PM
JPR Ram's Avatar
need for fuel press
Sorry, already sold it to another member several months ago.
pipeman90
Mar 29, 2011 09:23 AM
Mudinyeri
Aug 13, 2009 09:01 PM
wjbell
May 6, 2008 06:05 AM
Pinksa
16
Oct 7, 2007 02:51 PM
RadRam
Dec 9, 2004 08:41 PM
