Pyro probe question
Old Dec 13, 2007 | 06:37 AM
BgBlkTrk's Avatar
Pyro probe question
I went into my truck the other night to get some stuff out of it, and the EGT was showing 130-this is after the truck has been sitting for a few days and it was between 30-40 degrees out, so it was cold. So my question is, can the probe be cleaned/cal'd to read more accurately, or do I have to buy another one? This is for the Juice w/Attitude.
Old Dec 13, 2007 | 06:40 AM
Geico266's Avatar
EGT probes just are not that accurate due to the range of temperatures they are subjected to. Use them as an indicator of the EGT not for outside air temps.
Old Dec 13, 2007 | 08:16 AM
Jetpilot's Avatar
I might be suspect of the reading..... Normally a pyro will read close to the OAT if it has been sitting for awhile. Has the truck read accuratley previously? If it has I would replace the probe and see if that makes a difference.
Old Dec 13, 2007 | 11:44 PM
BgBlkTrk's Avatar
I got the Edge used and it has always read a little high. I let it cool down before I shut it off, but I have read about others that get their egts into the 300s before shutting off, and I am lucky to be in the low 400s after a few minutes. The thermocouples we use at work are accurate from 20-850c, the only difference being that they are external to the point being measured, so they do not get contaminated. I was just wondering if maybe the thing is coked up enough to set off the temps being read a little.
BHD
Jan 5, 2008 11:51 PM
tomd
Dec 12, 2006 10:56 PM
displacedtexan
Jul 14, 2006 11:03 AM
big pappa
Feb 27, 2005 10:00 PM
TinJim
Apr 28, 2003 09:50 PM
