Pyro guage light
Old Mar 7, 2006 | 08:05 AM
dodchall70's Avatar
Pyro guage light
I just installed Isspro guages about 2 months ago. Everything has worked fine until this morning. On the way to work the pyro guage light kept dimming about every 3 minutes or so. It would dim for about 1 minute, than it would go bright again. Does anybody have any suggestions on what to check?
Thanks,
Larry
Old Mar 7, 2006 | 09:32 AM
DodgeCowboy's Avatar
DTR's Cow Boss
i would check your grounds first to see if nothing came loose.
Old Mar 7, 2006 | 07:33 PM
HP Upgrades's Avatar
Double check your connections. Sounds like a loose connection somewhere.
Old Mar 7, 2006 | 09:08 PM
koogala's Avatar
My headlights do that every morn. about the 1st 3-4 minutes. Volt gauge will simetaniously drop when this happens. Dodge house says this is normal.... .. something about some kind of heating element or something. Headlights dim slightly then it goes away
Old Mar 8, 2006 | 05:03 AM
TexasCTD's Avatar
That is your grid heater kicking on and off. It pulls alot of electrical power and will make your lights dim momentarily. Once warm weather (say above 70 degrees) is here constantly.........it will go away until next fall or winter. It is completely normal. Dodge house is right on that one.
That may also be what could be dimming dodchall70's lights on his gauge, but im not sure on that one. It wouldn't just effect one gauge.........it would pull down all of his lights simultaneously for a minute, then brighten them all back up. His may very well be a loose connection.
Old Mar 8, 2006 | 07:35 AM
dodchall70's Avatar
Thanks for all of your help. I did check all the connections last night. Everything looked OK. It is not the grid heater because it is only the Pyro guage that is dimming. It did it again this morning on the way to work. It is like it is on a timer. It dims then gets bright again.
Thanks again,
Larry
Slugblaster
Sep 13, 2005 01:10 PM
Reelay
Sep 2, 2004 09:44 AM
Sidewinder
Mar 2, 2004 12:13 AM
cLAYH
Aug 27, 2003 01:50 AM
RAMTECH
Mar 9, 2003 12:49 PM
