Pyro guage installation?
Old Apr 30, 2004 | 09:04 AM
Reelay's Avatar
Question Pyro guage installation?
Going to install Pyro guage along with Trans. temp, and Boost. Question: Which Pyro guage is best, pre turbo or post turbo? I purchased ISSPRO guages from the ISSPRO here in Portland Or. They gave me the post turbo which is installed on the exhaust down pipe which is supposed to be drilled out and have a coupler welded in, of course to do this I have to remove the pipe. The other application is easier to get to {pre turbo}. So which is the most accurate. Also the Trans. temp has no instructions that give me any option locations to install the sending unit. I really don't want to drop the tranny pan and weld in the unit as leaks might occur then I would end up doing the job again. So if anyone has another location for the sending unit for the tranny temp it would be appreciated. I would be thankful for any technical response.
Old Sep 2, 2004 | 05:36 AM
LRod's Avatar
Reelay,
I'm going to install a X-Monitor and have found this post. It may help you. I'm going to use the test port. We'll see how it reads.
Rod
http://www.pirate4x4.com/forum/showt...t=towing+forum
2003 Ram 3500, SLT, Quad Cab, 5.9L6, H.O., 4x4, Auto 48RE,
K&N FIPK, Hog Performance 4" SS Exhaust
Old Sep 2, 2004 | 06:24 AM
nitrousn's Avatar
put the probe pre turbo. very easy to do. I dont think installing the trans temp probe is a pressure test port is a good idea. trans pan and line to the cooler would be better and more accurate imho.
Old Sep 2, 2004 | 09:44 AM
infidel's Avatar
Pre-turbo is the only way to go.
I've moved quite a few senders from post to pre, but never the opposite for good reason.
Diesel fitter
19
Jan 12, 2009 10:19 PM
Rrloren
14
Aug 4, 2008 10:38 AM
MikeyB
Apr 18, 2007 11:51 AM
Spooler
Mar 7, 2006 04:02 PM
FiverBob
Dec 29, 2002 07:36 PM
