PTO on Bully Dog?
PTO on Bully Dog?
As title suggests, does anyone know what PTO function on the BullyDog tuners is for? I cant imagine its Power Take Off like on a tractor....
If so, Im goin bush hoggin!
Location: Then, raised central PA; Now where ever Uncle Sam sends me.
Yes, on some trucks you can actually have a PTO put on the transmission to run either hydralics or same and electric generator. If you set it up to run hydralics that can power a snow plow in winter but also a hydralic electric generator any other time it is needed as well. There is also a hydralic kit available to go on the engine where the jake brake vacumn is to go that way you have constent hydralic pressure and never loose it when you step on the clutch like you would with a transmission mounted PTO drive set.
CLeger67
04-07-2008 08:17 AM
Townsend600
08-15-2007 10:05 AM
chevkiller
16
02-16-2004 01:14 PM
Push Rod
02-08-2003 07:51 PM
