Proposed Upgrades?
Old Apr 19, 2017 | 11:38 AM
TXPOWER's Avatar
Proposed Upgrades?
My son wants to do a little performance upgrading to his truck, 2003 QC 4x4 5.9HO with 200k on the clock. It's all stock except he strait piped the exhaust.
He wants a little more power. We have researched a lot and think a viable path is a Smarty Jr., monitoring (boost, egt, Fuel pressure), upgrading to a HE351w turbo, 4" downpipe and exhaust, maybe an Airdog 100 system and 50hp stix (not immediately).
Tranny mods in the future, when this one gives out, its the original.
I'm afraid to even put this part but you know how kids are. He wants it to roll a little coal, if possible. Yes, yes, I know, please don't beat me/him up. He works hard for the money he does things to his truck with.
Any input or a better plan in terms of power/performance is welcome.
Thanks to all,
TXPower
Old Apr 19, 2017 | 02:41 PM
CRF450R RIDER's Avatar
If he's just looking for a little more power, i would just start with the smarty and go from there. But if you plan on doing the injectors and turbo, i would go with better tuning like HP or UDC pro. Build that tranny like you mentioned.
Old Apr 19, 2017 | 04:35 PM
Mexstan's Avatar
For a small increase in power, slot the holes in the tone ring and increase the timing slightly. This mod costs nothing except time. Do a search on this mod for exactly how to do it.
Old Apr 21, 2017 | 03:04 PM
2-Stroke's Avatar
I like your plan. However, I would likely do the injectors only after transmission upgrade.
Old Apr 24, 2017 | 03:45 PM
TXPOWER's Avatar
More questions for the group. We are considering one of the Smarty's with POD, maybe a Touch or S06 so the tunes can grow with the mods my son does to the truck.
Can anyone answer this, are the POD's truly "on-demand", meaning, can he change the power setting without having to turn the truck off or go through some other elaborate process. I guess what I'm asking is can POD's be changed at the touch of button from stop light to stop light?
Also, I know the touch is a programmer and monitor all in one. Are there any monitors that work in conjunction with the S06 so he can monitor and still change POD settings? Any recommendations?
Last, on the Cummins, what are the must monitor PID's. I know EGT but what else?
Thanks,
TXPower
Old Apr 24, 2017 | 04:25 PM
I would monitor fuel pressure, rail pressure and oil pressure.
Old Apr 24, 2017 | 06:15 PM
TXPOWER's Avatar
CRF450R, I'm guessing he can buy a 3 pod gauge cluster and plumb the sensors to monitor each into each system fairly simply?
Thanks,
TXPower
Old Apr 25, 2017 | 12:27 AM
Thanks,
TXPower
yes. They edge insight CTS 2 is also an option. I haven't looked into that monitor that much, but i know you can monitor more then the first insight CTS.
Old Apr 27, 2017 | 09:26 AM
TXPOWER's Avatar
Can ya'll advise what level gallon per hour FASS we should go with that will cover his build from now till he's at 500 to 550hp?
Thanks,
TXPower
Old Apr 27, 2017 | 11:38 AM
Thanks,
TXPower
you won't need one, the stock pump will do just fine. But the better filtration will be a good thing to have to prolong the life of the injectors.
Old Apr 27, 2017 | 03:55 PM
TXPOWER's Avatar
So would you recommend one of the big line kits with 2mic filter setups instead if we don't need a more powerful pump?
Thanks,
TXPower
Old Apr 27, 2017 | 04:12 PM
BILTIT's Avatar
Thanks,
TXPower
Yes the POD is on demand, you can change it at anytime while the truck is running. POD is not like changing tunes though, it is more like re-calibrating the throttle pedal.
I find i don't change tunes much anyways, spring/fall or towing heavy is the only time i change the tune.
The Smarty Touch is a great monitoring device, the tunes are nice too.
Old Apr 27, 2017 | 09:48 PM
Thanks,
TXPower
yes. Something like this. http://m.dieselfuelfilterkits.com/?url=http%3A%2F%2Fwww.dieselfuelfilterkits.com%2F& utm_referrer=#2970 I don't think a true 2 micron absolute filter exists after i have done lots of research on filters, so i use Donaldson P551313 which is an absolute 3 micron filter. I actually have a water separator, a 5 micron filter and then my 3 micron filter.
kas83
Nov 21, 2007 08:19 PM
Totallyrad
Jun 22, 2007 05:02 PM
hotdram
Oct 7, 2005 11:03 AM
