Propane Kit Pressures?
Old Jul 18, 2005 | 12:33 PM
dodgeboy59td's Avatar
How much pressure do the normal propane kits run?
Old Jul 18, 2005 | 08:53 PM
Anyone have any Ideas?
Old Jul 19, 2005 | 12:27 AM
MR4WLR's Avatar
If you can't get info here I would suggest you call a vendor that sells propane systems.
Old Jul 19, 2005 | 06:21 AM
What type of HP does that give you?
Old Jul 19, 2005 | 12:03 PM
That was my thoughts, on making a homemade system. I already have regulators and pressure switches, just trying to get an idea what to set everything at.
Old Jul 20, 2005 | 06:35 AM
pcburnout's Avatar
I run the PS2000 all the time great addition to the way the engine performence is and MPG's are about 2-3 more. I talk with the tech on design and function and told it is a very safe system as at 5lbs boost it releases a very small amount of propane and is releasing full at 15lbs of boost. as for hp's the factory settings are 70hp and can be adjusted to 100hp but not recommend as if detenation is there your engine will be done!
Now my truck no long smells like a diesel it smells like a Bar-B-Q Grill!
Old Jul 22, 2005 | 05:36 AM
Thanks Guys for the help!
Flatbed24v
Jul 31, 2009 10:57 AM
fireram
Jul 18, 2008 07:07 PM
O.T
Sep 18, 2007 12:50 PM
toupee
Jun 27, 2007 04:19 PM
PowerDually
Jun 12, 2005 10:51 AM
