Problem With Quad!! Opinions??
what the heckkkkk,the 12v by far the best 5.9 out there,it sounds like a real truck,if i was able i would put a 12v in my quadcab,anyways,ive had a quad rp gauge and now the camander,ive never had an issue with iether reading rp,ive washed my engine bay also with no issues,it may be some fluke thing.
Could this be my problem??
I have had 3 or 4 race boxes on over the last 2 months with the same results, truck runs stock. I installed the X2 Monday and the rail guage will read between 1100 and 1200, 11K and 12K PSI. I called Quad ad they said that I have a pressure issue.
Does this sound right?
also quads customer service is second to none,im sure they will replace it and if it does it again they will give a refund or credit,i bouhgt a used camabder here and they offered to replace it when i thought i had a issue,turned out to be a wiring prob,{my fault}
Ya they have great customer service. But there rp gauges are KNOWN to have issues!! Even they said that to me yesterday.. I won't be putting it back on my truck after they replace it with a new one
It reads 6K at Idle and 10K - 12K when running. I have only hit 12K once or twice standing on it. The boost will show high 30s and 40 now and then.
Quad has been great to work with.
The truck starts and runs great, but the setting on the race box does not change the performance.
Any suggestions?? I have tried the old race and just installed then new X2 with the same results. Could it be something other than the fuel?
not sure what a frv thingy is but only 12k when rompin seems a bit low,ur 05 should at least see 17-20k even stock,i didnt notice much dif in the seetings on the x2 till i stacked it with the pred tuner,with the x2 on 5 on the smoke tune and no pred it seemed like trottle response was bit better but nothing really big,the pred by itself was a very huge gain and then with the x2 i notice a nice gain now.hope this helps
FRPV stands for fuel rail pressure valve. Being that you can only get 12k I would test your rail pressure valve. For an easy test you can remove it and cap it off...if your pressures are now normal then the valve is shot, if they are still low then you could have injector or injector tube issues as well as other (FCA, etc).
Dumb question but are you 100% sure that the rail sensor is bad? I'm not seeing the connection between just a rail pressure gauge and a sensor going out? The rail gauge doesn't add any extra pressure or change the pressure...it just measures it. If you clear the code will it come back immediately or do you have to drive it for a while? I'm leaning towards another cause like corrosion/moisture in the connector/harness or another failure of something causing the code. I could be wrong however but just can't see the relation between a rail pressure gauge and failed sensor.
Last edited by UNDER-PRESSURE; Aug 23, 2008 at 03:54 PM. Reason: Edit was needed...
Haulin_in_Dixie
Jul 7, 2023 02:13 PM
Luvnacumns
44
Mar 26, 2007 09:47 PM
RedRacer44
28
Feb 7, 2007 12:49 AM
hllbllyhellion
Aug 19, 2006 06:18 AM
robert chilton
27
Nov 3, 2005 12:23 PM
