Probe port for pyro
Old Mar 8, 2006 | 08:24 PM
HydraulicGuy's Avatar
Probe port for pyro
I'm installing gauges in a new to me 03' this weekend. Any particular spot on the exhaust manifold that I should drill / tap for the best results? How about an easy port for the boost. On my 00' I only had to pull a plug out to install a fitting for the boost. Any advice would be appreaciated.
Thanks
Old Mar 8, 2006 | 10:11 PM
Nate-03 D's Avatar
When I drilled/taped for the boost gauge I did it on the back side of the inlet. I guess you can drill the front but it just looked clean from the rear of it.
Let me know how the install for the EGT goes, I runied my manifold today trying to do mine. lol. Follow this link there is a picture where a fellow member taped/drilled his.
https://www.dieseltruckresource.com/...ad.php?t=95030
They reccomend you drill the hole on the farthest flange on the manifold. You will see where the manifold drops off and connects to the turbo, drill a hole in the port closest to the firewall. The picture in the link above pretty much sums it up.
Old Mar 9, 2006 | 04:45 PM
truckjunkie's Avatar
Take a look in my photo gallery for pics of my EGT - POST turbo install - of course mine is a 4.5.... I was able to just take the wheel well liner out and it was a piece of cake. Not sure if this'll help you with an 03 though...
As far as the boost gauge is concerned, I used a boost bolt I got from Dieselmanor. The install of the boost bolt was the easiest part of the gauge installation.
Old Mar 26, 2006 | 07:28 PM
bigwheels94's Avatar
Hey. I checked out your picture for the pyro fitting.& I put mine in allmost the exact same place.I was wondering what your EGT's were at full load.Mine run at 1100 degrees.Our trucks are also nearly identical.
Old Mar 26, 2006 | 07:50 PM
horsepoor68's Avatar
I drilled my 05 in the same location im seeing about 500 degrees at interstate speeds. When I ordered from genos i was told back off it1000.
Old Mar 27, 2006 | 12:59 PM
Sorry - I just revisited this thread. I'm one of those wimpy guys that doesn't really tow too much with my truck; not that I don't want to, but I'm married; there are a lot more toys that I want in the stores than in my garage or my yard :-)
So, my normal cruising EGT is usually 450 - 500, and 600 going up a hill or something. Now I have actually managed to get the EGT up to about 750 once, but that was at about 80 mph on a pretty good grade coming out of Santa Fe, NM.
I shut it down when the needle drops below 300.
Old Mar 27, 2006 | 05:41 PM
PZM123's Avatar
truckjunkie Was the elbow thick enough to tap for egt probe ?, or did you need to weld on a bun? Just ordered my gauges & think I will go post turbo.
Old Mar 29, 2006 | 09:25 AM
Where I tapped it in the elbow it was plenty thick. I think I got 4-5 threads in there with the tap - maybe more. Just make sure you put some anti-sieze on the threads before you screw it in.
Old Mar 29, 2006 | 10:55 AM
welndmn's Avatar
If you get an exhaust brake, I know Dodge puts the EGT on the elbow there.
If its good enough for dodge, I will put mine there too.
Utundra
Jan 27, 2008 08:22 PM
DSmith1178
May 30, 2007 07:38 AM
QWKRTNU
Sep 26, 2006 10:22 PM
HydraulicGuy
Feb 20, 2006 05:50 PM
