Pressure Boxes
Old Jan 11, 2006 | 03:51 PM
jerrywoodie's Avatar
Pressure Boxes
Which Boxes Are Pressure Only, And Which Ones Stacks W/the Edge Juice (hot) The Best
Old Jan 11, 2006 | 04:55 PM
wap's Avatar
wap
I dont know wich would be best, but the EZ, BDDL, and mp 8 will stack with it, at least that is what I have seen on here but I am sure somebody will be along in a minute to pick up my slack.
Old Jan 11, 2006 | 07:29 PM
RamWheelsBy4's Avatar
I personally have stacked the EZ and Bully Dog Triple Dog with the HOT Juice/Attitude. EZ was great stack, added just enough low end to remove the any lag on my SPS66. I did not really like the BDDL stack, both do timing and duration and hard to find setting combo that was streetable without too much smoke and heat. I quit using the BDDL. I switched to TST w/Twins programming in place of the HOT Juice for a little higher horsepower and more options when I can afford the real twins.
My HOT Juice is in the classified here.
Old Jan 12, 2006 | 09:33 AM
njmaier's Avatar
I have an EZ stacked with my Bully Dog. I set the BDDL on the lowest setting which is tow (50-70 HP and 100TQ). I hooked up the EZ on setting 2 (50HP and 180TQ). The power isn't quite as much as the BDDL alone set on extreme (130HP 250TQ), but I think the stacked power is much more drivable. The stack is way smoother, and it seems to have much better low boost power. I don't have as much smoke but that's not a big deal...I get a little puff when I step on it but not much else.
Old Jan 12, 2006 | 11:08 AM
hognutz's Avatar
I would just look for a good deal on a used ez. I am pretty sure the TS boxes will work as well. As to wich would work better I have not clue.
Old Jan 12, 2006 | 12:06 PM
Anybody With A Used Ez For 4.5 Or 05
Old Jan 12, 2006 | 12:17 PM
JCLeary's Avatar
Take a look in the classifieds. I'm sure you'll come up with one here or on TDR.
Old Jan 12, 2006 | 01:08 PM
hognutz's Avatar
there is one in classfieds for $300. on on ebay as well starting at $300 bin$350. when I was thinking of buying they were going for anywhere from $250-$320.
Old Jan 12, 2006 | 04:35 PM
NB64's Avatar
Hello, does anyone use the van Aaken SmartBox C3.2 on their realitively stock truck. I'm asking this since I can't afford to ask my wife (if it would be ok) to spend a couple grand to upgrade the trans on my 40K truck. Thanks
6 2 Carl
28
Apr 11, 2009 04:40 PM
t-boe
Jan 4, 2007 08:35 AM
scottrod
16
Oct 26, 2006 08:26 AM
dodgetech77
17
Sep 12, 2005 07:26 PM
SLEDHEAD
Sep 11, 2005 11:48 PM
