Power Loss above 2000 RPM with SMARTY & other stuff
Old Nov 3, 2010 | 09:57 AM
captntim's Avatar
Truck in my sig:
I have noticed on my last highway trip that I seem to have a loss in power in the mid-upper RPM range. Truck idles fine, runs smooth, has no codes or noises, & builds the same boost. I really notice it pulling away from a toll booth where it would always pull very strong...expecially once boost had built and RPM's were above 2000. I just don't seem to feel that kick in the a$$ like I used to. Vefy subjective, I know, but just throwing it out there.
I've done nothing yet, but I have a Raptor 100 lift pump & thought I'd clean the inlet screen and change the fuel filter...any other thoughts? I don't have a rail or low pressure fuel gauge.
Thanks in advance
Old Nov 3, 2010 | 10:18 AM
BPoulsen's Avatar
My only guess would be the fuel filter.
Old Nov 3, 2010 | 11:36 AM
05CTDN8's Avatar
What turbo? What program? How much boost above 2K? EGT'S above 2K? Rail pressure @ Idle, Mid & WOT?
Could be a popped Rail Pressure Valve.
Old Nov 3, 2010 | 12:48 PM
captntim's Avatar
I don't have a rail pressure gauge, so I can't answer that, but I'm running SMARTY #7 and haven't really noticed any differences in EGT's or boost. At 3/4 throttle above 2K, I usually see about EGTs about 1050 and boost is 22-24psi.
Turbo is stock 2003 SO motor...whatever that is.
Thanks for the reply. Maybe I should cap the pressure relief valve and give it a try...
Old Nov 3, 2010 | 02:28 PM
05CTDN8's Avatar
I would definately get a RPG and see what your pressures are now!
Also, you are not "making oil" right?
Old Nov 3, 2010 | 03:14 PM
homewrecker's Avatar
maybe you've just gotten use to the hp your at and need more!
your on the right track with stuff to check and the rp would be a good thing also. The local dodge place will let you take a drive with a tech and Starscan hooked up for 1/2 hour shop labor rate. Cheaper than buying a $200 rp gauge.
Old Nov 3, 2010 | 05:29 PM
captntim's Avatar
Thanks for the replies. Oil level hasn't moved and is staying pretty clean. I would like to reconfigure my gauge situation and add a RPG, but I really should sell my Edge first to help with the cost.
Also, I am on a boat and will have a 500+ mile drive home before I'd be able to mess with this. Hopefully there won't be any consequences.
RIKX500
Aug 7, 2014 06:53 PM
kimber
Nov 16, 2012 05:23 PM
danimal24
Nov 27, 2009 03:42 PM
jsflagstad
Jun 10, 2007 06:43 AM
chippenjj
Aug 30, 2005 09:44 AM
