Power loss above 2000 RPM while driving - Truck stranded
Hello all - first post, but badly need info on this rather urgent question.
While in 1st gear & moving, truck has power up until it hits 2000 RPM @ 20 MPH. Few points of interest below:
* While power braking in gear (0 MPH), truck has lots of power and does not cut out at 2000 RPM - and it is throwing a lot of smoke.
* Only does this while in motion
* Throws a P236 code after a few times running on street
* Place truck in 4 Low, truck goes to ~8 MPH, but still hangs at 2000 RPM
Bottom line it seems to be speed sensitive but really limited to 2000 RPM while in motion -even as I lightly touch the pedal, thus not much load at all.
Any ideas? Thank you and let me know. Truck is stuck at my friends house.
2002 Dodge RAM2500 4x4, Edge Comp, Stage II Auto, 100HP Inj, 150 GPH FASS Pump, ATS Co-Pilot
Thx. No smoke while in motion, only when I power brake it to overcome the TQ Conv stall-speed.
A bit more info with the day light.
While power braking (Edge Comp turned up) it DOES as well limit itself to 2000 RPM.
I have bypassed both the Edge & Co-Pilot - still limits to 2000 RPM and will not shift out of 1st (both in Hi-Range & 4-low).
Weird.
Still get a p236 code - but not consistantly.
Weird.
Weird.
Weird.
I removed the Edge Comp.
Still no luck. It was VERY intermittent, now will NOT go away.
It will rev to the moon while in Neutral.
Put it in D, governs at 2000 RPM. I the p236 code has not come back. Another weird scenario.
kimber
Nov 16, 2012 05:23 PM
captntim
Nov 3, 2010 05:29 PM
danimal24
Nov 27, 2009 03:42 PM
jsflagstad
Jun 10, 2007 06:43 AM
chippenjj
Aug 30, 2005 09:44 AM
