Popping Sound At Full Throttle.
Old Nov 28, 2007 | 03:47 PM
iwantmud's Avatar
I dont know what is happening but when i am accelerating with my PMT and torque dog turned all the way up it is makeing a poping sound. Any ideas on what it could be?
Old Nov 28, 2007 | 03:50 PM
Spooler's Avatar
Sounds like you don't have enough fuel due to a delivery issue. Did you upgrade your LP?
Old Nov 28, 2007 | 03:51 PM
dodgezilla04's Avatar
yes, you are draining the rail. if you install a rail gauge, you will see the pressure drop significantly and then the popping starts.
the popping really isnt a good thing. for the injectors to atomize and spray the fuel in a good pattern they need the pressure that they were designed to run.
low pressure results in a poor pattern and egt's will get pretty high.
Old Nov 29, 2007 | 02:35 PM
iwantmud's Avatar
My egt's do get hot really quick. What can i do to upgrade my line pressure so it will stop.
Old Nov 29, 2007 | 02:55 PM
tcr's Avatar
tcr
WHat kind of fuel system(LP) do you have? What size lines to the CP3?
Old Nov 29, 2007 | 04:30 PM
iwantmud's Avatar
I have know idea.... whatever is stock?????
Old Nov 29, 2007 | 04:44 PM
kantdrive55's Avatar
DTR Advertiser
A big line kit or an upgraded CP3 with an auxillary lift pump should help your fueling needs.
Old Nov 30, 2007 | 08:41 AM
iwantmud's Avatar
Any suggestions on a company with a good big line kit and aux fuel pump.
Old Nov 30, 2007 | 08:47 AM
wap's Avatar
wap
glacier diesel power
Old Nov 30, 2007 | 09:15 AM
iwantmud's Avatar
what about an aux fuelpump
Old Nov 30, 2007 | 03:03 PM
wap's Avatar
wap
CP3 or lift pump? GDP has the big line kit and a coupla differant options on lift pumps.
Old Nov 30, 2007 | 03:12 PM
OT-OF-Here's Avatar
Several things cause it,..
Primarily it will be too much timing for your setup. Also excessive pressure from a pressure box will cause it. Those are the two primary contributors.
Old Nov 30, 2007 | 06:24 PM
Sasqoutch's Avatar
Get the walbro 392 and big line kit from glacier diesel power. Dont forget a fuel pressure gauge and like they said, a rail pressure gauge would tell you what kind of pressure your running in there.
Old Nov 30, 2007 | 06:28 PM
Cummins610's Avatar
Is surging also a sign of CP3 short of fuel? A LP and a Big Line kit are my next mods.
Old Nov 30, 2007 | 10:23 PM
OT-OF-Here's Avatar
Surging
Usually that's the turbo,.. a big single most times. Whatcha running?
