ponci's event, new times and a new warning
Old Aug 8, 2009 | 06:22 PM
soulezoo's Avatar
DTR 1st Sergeant
Ponci's drag day was a great event and the weather was perfect.
I have a new time of 11.89 @ 119mph. So I am now officially in the 11 second club.
I am also in the "I blew the rear freeze plug" club. On my last pass, (it is always the last pass isn't it?), I blew the freeze plug at the end of the track... Just like many others before.
Here is the warning though, I have an Opies bypass kit installed that is supposed to prevent this. Before I go any further, do not take that last statement as a bash on Opies bypass. The point I want clearly understood is that because you have a bypass, -I suppose regardless of mfg-, do not fall into a false sense of security like me and think you are covered!
Happy dieseling!
Old Aug 8, 2009 | 06:28 PM
MikeyB's Avatar
Bummer.
MikeyB
Old Aug 8, 2009 | 07:03 PM
jaredb900rr's Avatar
Congrats Terry! Gotta one-up me, eh. You got me by .02 seconds...guess I better get out to the track again, hehe. Your trap speed indicates there's even lower ETs still in her!
Old Aug 8, 2009 | 07:05 PM
Sorry to hear bout the blown freeze plug. Were you running a 4K RPM tune?
Old Aug 8, 2009 | 07:21 PM
madhat's Avatar
Administrator/Jarhead
WHOA! Wait a minute! I thought that the bypass was supposed to prevent this?
Old Aug 8, 2009 | 07:53 PM
soulezoo's Avatar
DTR 1st Sergeant
Yes I was... And yeah Mad, the bypass is supposed to prevent that, which I why I am putting out the warning!
This is hard on my blackberry folks!
Old Aug 8, 2009 | 08:35 PM
madhat's Avatar
Looks like it's time to weld those plugs in, huh?
Old Aug 8, 2009 | 08:47 PM
soulezoo's Avatar
DTR 1st Sergeant
Weld? Maybe so!
Or I maybe having dual coolant bypass units...
Old Aug 8, 2009 | 09:03 PM
OldSmokey's Avatar
Interesting!!!! I wonder what else may be causing the plugs to blow out.
Old Aug 9, 2009 | 08:49 AM
nevrnf's Avatar
What is the flow pressure set at on the Opie's kit???? I know you can buy a universal valve and it can be set at any pressure.
Also what water pump are you running? I just replaced the water pump and it had a smaller impeller and a cover/shield that looks like it will reduce the flow/pressure.
Old Aug 9, 2009 | 08:59 AM
mikmaze's Avatar
time to nip two fins off the water pump........ great time on that run bud, how was mph ?
Old Aug 9, 2009 | 09:45 AM
soulezoo's Avatar
DTR 1st Sergeant
119.......
Old Aug 9, 2009 | 10:08 AM
megacabdad's Avatar
Great run!
Sorry to hear about the freeze plug, tho...
Do you spray water or nitrous?
Old Aug 9, 2009 | 10:09 AM
Blueboy's Avatar
TRE sells a Alum plate to cover the back plug, but it could still
blow somewhere else.
Old Aug 9, 2009 | 11:05 AM
Don M's Avatar
DTR Advertiser
Some of the blocks had a somewhat sloppy fit on the plugs. There was a slightly larger plug released back a few years to replace them with.
Too bad Cummins did not make the "storm" block a full "storm" block and thread the water plugs in as well as the rest of the plugs when they made the change.
When I assemble engines I use locktite 620 on all the plugs. Oil and water. I have NEVER had one pop out. I also run a 600 flex hone very lightly pre the laquer thinner and # 620. Hone, laquer thinner, # 620 = zero failures. Very light on the hone. It is more to clean the area than opening it up. You dont want it opened up at all.
I used to have these visions of someone popping a plug at the race track and lowering friction enough to slip around on the track surface. Imagination can fill in the rest of the story.
