PML diff cover question
Old Apr 17, 2005 | 12:22 PM
Lightman's Avatar
The factory cover specs 30 ft lbs of torque on the bolts. The instructions with the PML pan say 15lbs, but use your factory specs if they are higher. I was just a little leary of torquing too much into aluminum. What have you guys done?
Old Apr 17, 2005 | 07:49 PM
MikeyB's Avatar
Torqued my PML cover to about 15 ft. lbs. No leaks so far.
MikeyB
Old Apr 17, 2005 | 10:59 PM
Neil58's Avatar
Same here....15 FT LBS per factory directions.....no leaks.
Old Apr 18, 2005 | 06:51 AM
Lightman's Avatar
Thanks guys. I ended up doing 17lbs all the way around. It looks better than I expected.
It took just about 5 quarts before it ran out of the hole. Is this about what you guys added? I wasn't sure I was on exactly level ground...
Old Apr 18, 2005 | 07:18 AM
MikeyB's Avatar
Yep, mine was exactly 5 qts.
MikeyB
Old Apr 18, 2005 | 09:23 AM
Lightman's Avatar
Sounds good, thx MikeyB. That's quite a jump in capacity.
Holy cow you have a lot of accessories in your sig. Time for an xzillaraider MikeyB!
Old Apr 18, 2005 | 11:47 AM
MikeyB's Avatar
I have been thinking about the XZT version. Just can't make myself jump over to the dark side yet!
MikeyB
Old Apr 18, 2005 | 02:09 PM
Original Junior's Avatar
Shoot, where were these answers 2 months ago . I actually torqued mine up to about 28 and used red loctite on the bolts. I noticed the factory bolts had thread locker on it so I figured the PML's should too . This was on the second round. The first time I didn't torque them up as much and did not use thread locker and had seepage around the drain plug and bottom bolts. Oh well, live and learn. So far so good.
dtc503
Jun 11, 2006 03:51 PM
cditrani
13
Dec 4, 2005 09:42 PM
HighTen
Feb 23, 2005 02:51 PM
davelinde
31
Jan 28, 2005 05:38 PM
MikeyB
13
Jan 24, 2005 07:16 AM
