Pioneer AVIC-N2 Install, Questions??
Old Mar 14, 2006 | 11:19 AM
PG4x4's Avatar
Originally Posted by thejeepdude
I tapped into the VSS at the tranny instead for my AVIC-N1. It was a short easy run from the firewall, the wire is concealed well, and it was easy to access once I figured out which wire to tap. It's been working perfectly for 30k miles now... if I remember correctly, it's a green striped twisted pair of wires that connect on the driver's side of the tranny, one with a stripe... used the FSM to determine exactly which one, not sure now but it was a lot easier than tapping at the ECM.
VSS? Vehicle Speed Sensor? What do u need that for?
Old Mar 14, 2006 | 11:38 AM
thejeepdude's Avatar
So the AVIC can track where you are and how fast you're going when GPS signal is lost (forest, tunnel, etc). The nice thing is, it's calibrated by GPS over time, and once calibrated is accurate to within .1 MPH, and the ~1sec dalay inherant with GPS speed detection is bypassed... makes it nice when driving through notorious speedtrap areas!
Old Mar 14, 2006 | 02:18 PM
roadie00's Avatar
Is the wire that needs to be tapped into in a large bundle or is it pretty much by it's lonesome? This may be a stupid question... What's a FSM?
Thanks again!
Old Mar 14, 2006 | 02:55 PM
Thanks again!
Yes, it's a green striped twisted pair of wires... meaning there are 2 wires twisted around each other, encased in a loom. It's a 2-wire plug on the tranny.. ok now you're going to make me look it up... Dark Green with Brown stripe
.... ok here's the original thread:
http://www.tdr1.com/forums/showthrea...&highlight=vss
There's a pic of the connector...
Does that help?
Oh yeah and FSM = Factory Service Manual
Old Mar 15, 2006 | 08:47 AM
roadie00's Avatar
Does that help?
Thanks a bunch!
Old Mar 15, 2006 | 02:52 PM
PG4x4's Avatar
I jsut upgraded the softwear on my N1 to N2 and now I can't drive and watch dvd. How do u bypass the the n2? Asoon as it gets about 25kmh the picture cuts out.
Old Mar 15, 2006 | 03:08 PM
roadie00's Avatar
Sent ya a PM...
snowmanx
Oct 8, 2007 07:46 AM
snowmanx
Sep 14, 2007 10:37 PM
wazz_zup
Jun 1, 2005 08:34 AM
NJMurvin
Jul 30, 2004 04:33 PM
