Pacbrake delay
Old Mar 13, 2006 | 10:31 PM
Sailpipes's Avatar
Pacbrake delay
Is there any way to adjust the delay before my Pacbrake comes on? Before, unless I shifted particularly slow, I wouldn't have to worry about it coming on between shifts. Now with the larger solenoid, I have to shift a lot quicker than I would like to, to keep it from coming on. Seems like it takes a little less than a second for it to start up once I take my foot off the accelerator. I did call Pacbrake to ask them directly but the only thing the guy there could suggest was putting a microswitch on the clutch pedal to keep it from coming on when the clutch is depressed.
Old Mar 13, 2006 | 11:14 PM
dodgezilla04's Avatar
the switch on the clutch pedal is the easiest/cheapest. are there icecube relays with delay built into them? maybe a wiper relay with fixed intermittent wipe time would work to replace the icecube relay on top of your compressor.
USMC64-70
Dec 23, 2004 08:27 AM
Idaho Guy
Nov 19, 2004 06:45 PM
Jason
Apr 19, 2004 12:40 PM
Jack Thorpe
Nov 6, 2003 01:25 PM
