Pacbrake, before I pull the trigger, question
Old Jul 25, 2012 | 06:31 PM
GreyTD's Avatar
I just bought the viair kit 20001 myself. I talk to pacbrake and they said max pressure the brake can take is 145psi (prefer 135psi). So I bought a regulator to feed brake.
ubet, where did you mount tank and compressor? Do you have pictures? Trying to find the place for the new system. Tks
Old Jul 28, 2012 | 10:04 AM
ubet's Avatar
It got mounted on the frame below the passenger side. I can take pictures later today maybe.
I need a regulator too, how and where are you going to put yours, because I still want the 200 psi for tires
Old Jul 28, 2012 | 10:15 AM
GreyTD's Avatar
I have two ideas one is put it on or near the tank, and two put it on the firewall right above the brake. Liking #2 a bit better so I can see gauge easier. The regulator only needs to be on the line that feeds the brake. That way everything else is still at 200psi.
Old Nov 16, 2012 | 08:22 PM
ubet's Avatar
Well I finally got around to installing a regulator today. It makes all the difference. To not be having to turn the tank on and off all the time while I am driving. The switch for the tank is located under the drivers seat, but still a pain in the *** to remember to shut off if I am driving. I tied the regulator right into the cylanoid for the brake, it isnt clean looking, but it seems to work fine so far.
jbworm20
Sep 26, 2007 01:29 PM
RyeThomas
24
Oct 28, 2006 07:37 PM
flyfsh70
May 24, 2006 09:56 PM
hotdram
Sep 20, 2004 12:57 PM
Brules
25
Jul 14, 2004 05:28 AM
