Overhead Pod/Gauge HELP
Old May 3, 2007 | 08:51 PM
ohyeahfriday's Avatar
Question Overhead Pod/Gauge HELP
OOOOK, so I got 2/3 of my gauges today (Isspro pyro and fuel pressure if that matters), as well as my overhead triple gauge pod. Now, the gauges have 2 long threaded studs on the back of them which are tooooo long. When I try to put the gauge in the pod, the studs bottom out on the back of it before they seat nicely in the openings. Can anyone see why I can not cut like 1/2" or so off to make them fit? They look like they are just for mounting purposes, I don't see any problem, but wanted to ask around first.
Also, any pointers in regards to mounting the overhead pod? I see where it says to cut a metal piece to get the pod to sit flush, do I have to yank the entire head liner for this job? I know some have had bad experiences, but I am a stubborn , and want to try it anyway. My hope is to mount the pod tomorrow nite, and let it sit empty until Sunday, then do the full install. This way the adhesive has some time to sit and "cure".
TIA, any info MUCH appreciated.
Pat
Old May 3, 2007 | 09:51 PM
koogala's Avatar
Cut them as needed. The gauges are factory built, multi purpose to fit many
applications. They are mounting studs with threads to spare. Somebody somewhere in the world needs them right now........but not most folks...
Old May 3, 2007 | 09:57 PM
Thanks for the reply, this is what I was figuring on, could not see why in God's name there needs to be like 1 1/5" of threaded rod hangin out back there.
BTW, if you run into somebody that needs all that threaded rod, shoot me a PM and I will Fedex it priority overnite to them after I hack it off
Old May 8, 2007 | 09:02 PM
Soooooo, has anyone here successfully put 3 gauges in a widnshield mount? Havint a hard time with mocking them up. specifically, can not see how in the world you can get all teh gauges/wires/tubes in there and THEN tighten up the nuts to hold the mounting brackets...
Help if ya can.... Thanks.
Old May 9, 2007 | 03:06 AM
bpdp379's Avatar
https://www.dieseltruckresource.com/...23&postcount=9
Hope that helps? It was real tough to get the nuts onto the back part.
famous grouse
Sep 14, 2008 12:14 AM
H8GAS
18
Aug 3, 2007 06:31 PM
lawnmaniac883
May 18, 2007 08:50 AM
powerstrokin03
Mar 5, 2007 08:26 AM
jeeptjstud
Nov 18, 2006 08:27 PM
