Outlook HP ??
Outlook HP ??
How can Bullydog Outlook calculate the HP and Torque numbers.
I understand that it's not very accurate or is it, but how far off would it be?
Thanks in advance
Thanks in advance
Mine was about right but it was doing it more to what the hp at the flywheel would be. Also DDP has proven the Outlook will kill 30hp at the wheels even with defuel points set at their max. When they took it off they picked up 30hp at the wheels with no other variables changed.
The HP calulation on the outlook is an equation based on 1/4 mile time. The truck weight in the equation is a set estimated value. It should be pretty close if you run an all out 1/4 mile.
anestech*
26
11-15-2004 01:02 PM
anestech*
11-07-2004 12:18 PM
zzsdad
11-05-2004 05:54 PM
quantrill88
10-04-2004 11:36 AM
