Oring Specs
Old Mar 10, 2008 | 11:08 AM
Bean's Avatar
Oring Specs
What are most guys using for specs on orings for the head? I have only been doing fire rings and gonna oring one and need to know what to make the groove and wire.
Old Mar 10, 2008 | 11:09 AM
PourinDiesel's Avatar
Whats wrong with the stock MLS gasket?
Old Mar 10, 2008 | 11:32 AM
Jetpilot's Avatar
I normally use a .041 stainless steel semi hard wire (I like BHJ wire). The groove is cut .039 with .010-.012 protrusion. You can also go with .051 wire and use a .049 groove, same protrusion amount.
Doug
Old Mar 10, 2008 | 12:09 PM
matego's Avatar
madhat's monkey boy...
I am wondering the same thing. I thought studs and stock head gaskets worked great even in the big HP trucks.
Old Mar 10, 2008 | 12:13 PM
Jetpilot's Avatar
The MLS gasket works very well for most...... But sometimes it just isn't the solution. That said a good o-ring job can be the answer.
Doug
Old Mar 10, 2008 | 01:11 PM
Bean's Avatar
Are you using the oldr 24 gaskets or the MLS gaskets with the orings? This wants this truck to be able to hold up to 1k hp down the road but probly wont be that for awhile thats why i am opting for the orings for him instead of fire rings and IMO stock MLS isnt gonna be enough even with stud, but I could be wrong.
Old Mar 10, 2008 | 01:18 PM
Timinva's Avatar
DTR Advertiser
I am running 041 wire in both my trucks. 013 pro. on the 04 and .011 on the 06. The wire is a little harder than what Doug recommends but they are both holding fine. MLS has not worked on my trucks. Tim
Old Mar 10, 2008 | 01:29 PM
Bean's Avatar
How wide of a groove to hold the wire on those? And are you using a ss wire?
Old Mar 10, 2008 | 01:57 PM
Timinva's Avatar
DTR Advertiser
My grooves are .039" wide. We start them with a lead mallet then push them the rest of the way with a aluminum torque plate. My wire is inconel. Tim
06RAMCTD
0
Dec 19, 2006 04:15 PM
Jambbii
Dec 28, 2005 12:12 AM
scottsjeeprolet
Dec 19, 2005 09:20 PM
justinp20012500
13
Dec 3, 2004 06:45 PM
