Ordering Gauges Today - Quick Question
Old Dec 8, 2006 | 12:58 PM
supercharged_hp's Avatar
I am ordering some gauges from a local shop today, but I have a quick question. If I don't get a "boost bolt" type fitting, will I have to drill/tap the intake manifold or is there something easily made to simulate the boost bolt?
http://www.dieselmanor.com/dm_products/DM-BSTBLT.asp
I will order it from diesel manor if I have to because I'd rather not have to drill/tap the intake... I can't tell from the pic what the male end threads are.
The gauges are the Autometer Phantom II EGT, 0-60 psi Boost and Trans Temp in an a-arm triple pod. Anything else I'm missing or I should know for the install? I guess other than a 1/4" tap for the EGT probe (pre-turbo of course).
Thanks
Old Dec 8, 2006 | 01:26 PM
BPC's Avatar
BPC
David includes the boost bolt with all his guage kits, use it - quick and easy.
Old Dec 8, 2006 | 06:14 PM
06megacabman's Avatar
I would do the boost bolt also. I'm new to the cummins thing and even I did it myself quick and easy with the Autometer gauge.
Old Dec 8, 2006 | 06:18 PM
goodeyesniper75's Avatar
the boost bolt is easy to use and quicker then drill and tap. the only other thing you should need are zip-ties lots.
Old Dec 8, 2006 | 08:27 PM
Thanks guys, I'll order one tomorrow.
The local speedshop gave me a hell of a deal on the gauges, even better than Dieselmanor, but they won't be here for a month... guess its gonna be another month of babying it
Old Dec 8, 2006 | 08:36 PM
Luken's Avatar
The boost bolt is by far the easiest and quickest way to hook the gauge up!
Old Dec 8, 2006 | 09:14 PM
I just figured out how to search the member's galleries and managed to find a pic of them.
You guys think these are going to be too bright at night? Maybe I should have got the dimmer too... I've never had Autometers that were LED lit before, my old Ultra-lites seemed far less bright.
RyeThomas
15
Jun 7, 2010 08:17 PM
sallyman1
20
Mar 3, 2008 09:36 AM
Heston_ram3500
Jan 16, 2007 11:18 PM
sadlerb_98
23
Mar 25, 2006 08:40 AM
B-rock
Apr 25, 2005 09:37 PM
