One Gauge Two Source Question
Old Dec 6, 2009 | 03:52 PM
bigjohn04's Avatar
Here's what I have, a Dipricol Optix trans temp gauge with the sender in the back of the Mag Hytec pan. I'm also running a Mag diff cover with a temp port ready for a sending unit.
My question is if I have a second temp sensor same as the trans I should be able to put it in the diff cover and wire it to a single pole double throw switch to where I could sellect which temp source I want to view with the gauge.
Please let me know if I'm crazy or if the voices in my head are right on the money.
Old Dec 6, 2009 | 03:55 PM
bansh-eman's Avatar
Theretically yes, it should work. Will it? I don't know...
I don't see why not. All your doing is changing the source that the electric gauge is recieveing it's info from.
Old Dec 6, 2009 | 05:25 PM
.boB's Avatar
I'v tried it. It works exactly as you describe. You could even use a rotary switch and monitor 3-4 sources with the same gauge.
Old Dec 6, 2009 | 05:36 PM
bigjohn04's Avatar
Sounds like I have a small project for next weekend. Thanks
Old Dec 6, 2009 | 05:54 PM
trksrfun's Avatar
sounds like a good idea, please post pics of the install when your finished..
seldomseen
Dec 3, 2010 09:50 AM
BearKiller
Nov 4, 2008 09:42 PM
dieselcarpenter
Nov 17, 2007 07:02 PM
crobtex
Oct 15, 2006 09:59 PM
Dieseldude4x4
Jan 4, 2003 03:07 PM
