Ok, a little worried
Old May 11, 2009 | 06:41 PM
rock crawler's Avatar
My Isspro Performax Fuel Pressure Gauge started showing 40 psi anytime the key is on.(pegged all the way) I have unplugged it and plugged it back in, turned the truck off and back on, and it will not change. Truck and AD150 run fine and sound fine. What gives? I had an issue with it last week dropping to zero and going back to 18 psi everytime I came to a stop.
Old May 11, 2009 | 07:19 PM
berok's Avatar
Just sounds like a bad gauge to me.
Old May 11, 2009 | 09:58 PM
madhat's Avatar
Administrator/Jarhead
Check your connections from start to finish on the gauge. Try cleaning them.
Do you read pressure directly from the fuel, or is it electronic? Is there an isolator?
I had a problem with my FP one time, I took an air hose, set it to 20 psi, and blew air into the FP line (unhooked from the fuel line) to make sure my gauge was not bad. I have also had an isolator that was crap, now I just run fuel straight into the cab.
Old May 12, 2009 | 09:00 AM
soulezoo's Avatar
DTR 1st Sergeant
No Smoking in Madhat's truck!
Old May 12, 2009 | 11:24 AM
'strokeThis_'07's Avatar
The Performax has a sensor that you thread into a banjo bolt. Then the harness from the processor plugs into the sensor. No isolator or fuel lines into the cab
Heston_ram3500
May 18, 2009 03:03 AM
thesundancekid
May 27, 2008 09:29 AM
brickhoss
Jun 6, 2007 06:38 AM
93beater
Mar 8, 2007 12:25 PM
Graphite600
Feb 12, 2006 06:19 AM
