Oil pressure warning light...or lights?
Old Jun 12, 2007 | 10:15 AM
cquestad's Avatar
Does anyone know if there is such a thing?
I would like to have one or two warning lights...one for low pressure...say 30 psi ( I don't know what values yet...that is another part of this discussion) and a high warning light at 60 psi in the cab. I have too many gauges allready...and would only like to have a "test gauge" under the hood...but lights in the cab.
Any ideas?
Old Jun 12, 2007 | 10:20 AM
cquestad's Avatar
http://www.jegs.com/webapp/wcs/store...45556_-1_10337
This one has a light WAY to big...but I guess I could find another lamp?
Does anyone know where to source some more resonable sized ones?
Old Jun 12, 2007 | 10:28 AM
cquestad's Avatar
http://www.jegs.com/webapp/wcs/store...45853_-1_10337
There are senders only for 15, 30, and 50 psi...i guess I should look first and post later...duh.
What are the "normal" oil pressure ranges for these trucks?
Old Jun 12, 2007 | 10:30 AM
THURENfab.'s Avatar
Looks like you found a good one..
Old Jun 12, 2007 | 11:28 AM
trik396's Avatar
Christian, that autometer is the one I have mounted on my dash. Funny thing is there is no 15psi sender. It's an 18psi one and that's the lowest Autometer has. Works great. It saves me from constantly glancing at my oil pressure guage. It's always nice to see it working. When I turn my key on, the light goes on, so I know it's working. Then it shuts off a few seconds after I start when pressure has risen. Cheap insurance for my engine and for my driving skills...
Old Jun 12, 2007 | 12:42 PM
cquestad's Avatar
So...what are considered the norm for oil pressures?
I would like to do a high and a low if I can...
Old Jun 12, 2007 | 02:08 PM
trik396's Avatar
Well I've never tripped the low pressure and my Autometer electric oil pressure guage at it's lowest shows around 20psi. This is with ChevDelo15w40 and 90degree temps. So it never hit 18psi on the low end. On the high end I've tickled 75psi when oil is cold in cold weather. It may be a touch higher, like 80psi. Once warmed up I see anywhere from 50 to maybe 65psi on the highway depending on speed. I usually drive 55 when I have to and 75 when I can. Hope this helps.
Old Jun 12, 2007 | 02:13 PM
53 willys's Avatar
OIL PRESSURE
@ Idle 69 kPa (10 psi)
@ 2,500 rpm 207 kPa (30 psi)
Regulating Valve Opening Pressure 517 kPa (75 psi)
oil filter Bypass Pressure Setting 344.75 kPa (50 psi)
Old Jun 12, 2007 | 02:18 PM
trik396's Avatar
53 ******, does this mean anytime my pressure is above 50psi that I'm pumping dirty oil thru my motor???
Old Jun 12, 2007 | 02:25 PM
53 willys's Avatar
thats what it sounds like to me????
I just looked it up in my manual.......
Old Jun 12, 2007 | 02:27 PM
trik396's Avatar
That doesn't sound right...
Old Jun 12, 2007 | 02:45 PM
53 willys's Avatar
I am pretty sure thats right....
most oil systems are pretty low psi...i have a high psi pump on my jeep and it is 50 psi max.
Old Jun 13, 2007 | 07:11 PM
cquestad's Avatar
Where did that info come from?
I though low idle was 30ish and high was around 50 psi?
hmmmmm....
The OEM gauge is worthless.
Old Jun 13, 2007 | 09:06 PM
trik396's Avatar
I think the numbers he quoted may be the LOWEST allowable pressures. I've never gone below 20psi or so. And I always see higher than 30psi at 2500rpms. Heck I'm at 30psi as soon as I touch the throttle.
Old Jun 13, 2007 | 11:20 PM
53 willys's Avatar
those are the specs for testing oil pressure right out of the book.....
I was told the gauge does not show true psi as far as the number goes???
